Four point plane to Point+Vector Plane?
http://code.google.com/apis/sketchup/docs/ourdoc/geom.html#introduction
A plane can be represented as either an Array of a point and a vector, or as an Array of 4 numbers that give the coefficients of a plane equation.
How does one convert a plane defined by four points to a plane defined by
[ point3d, vector3d ]?"coefficients of a plane equation"
Just a small correction, when you say "a plane defined by 4 points" you really mean a plane defined by 4 numbers (which are the coefficients of the equation of the plane.)
hmm...
always read "numbers" as "Point3d"s...
I never used or encountered anything other than the[ point3d, vector3d ]variant, but I want to make a method to ensure that's the format I get planes in. -
http://local.wasp.uwa.edu.au/~pbourke/geometry/planeeq/
The standard equation of a plane in 3 space is
Ax + By + Cz + D = 0@unknownuser said:
The normal to the plane is the vector (A,B,C).
So given a plane of
[a,b,c,d], the normal would beGeom::Vector3d.new(a,b,c)?
But what isd? And I don't see where I derive any point3d from this - to fit[ point3d, vector3d ]... -
Think it makes sense now....
Did some testing:
p1 = [200,200,200] [200, 200, 200] p2 = [400,200,200] [400, 200, 200] p3 = [400,400,200] [400, 400, 200] p4 = [200,400,200] [200, 400, 200] Geom.fit_plane_to_points(p1,p2,p3,p4) [-0.0, -0.0, 1.0, -200.0] -
d is just a constant, so unless theres an error in the docs (i.e. they mean 'you can define a plane with a vector and a constant', not unlikely) then youll have to find a point on the plane.
This seem to work.
# Return a plane in the format [ point3d, vector3d ] def self.normalize_plane(plane) return plane if plane.length == 2 a, b, c, d = plane v = Geom;;Vector3d.new(a,b,c) p = ORIGIN.offset(v.reverse, d) return [p, v] endWhen I test it:
p1 = [200,200,200] [200, 200, 200] p2 = [400,200,200] [400, 200, 200] p3 = [400,400,200] [400, 400, 200] p4 = [200,400,200] [200, 400, 200] plane = Geom.fit_plane_to_points(p1,p2,p3,p4) [-0.0, -0.0, 1.0, -200.0] TT_Lib;;Geom3D.normalize_plane(plane) [Point3d(0, 0, 200), Vector3d(0, 0, 1)] -
Its just not efficient. A plane is commonly defined by a direction and a distance along that direction (the "D" constant). Keep in mind a plane is infinite so you just need "a point" - any point on the plane to define it.
So explicitly storing the Point3d is (groan) pointless. If you want a point on the plane from its plane equation you just do:
plane_normal.scale(D)
ie You just need to store 4 values not 6 as you are doing.
Also you really don't want 4 points as input as they may not be coplanar. 3 points are guaranteed to be coplanar.
Yea - I'm not dealing with points. As remus pointed out to me, it was four numbers. I just wanted a method that'd convert a plane defined as four numbers into
[ point3d, vector3d ]- as theGeommodule says planes can be in either format.
