    Help with strange behavior SketchUp 7
    3 Posts 2 Posters 458 Views 2 Watching
    • J
      Joarek
      Hello all, this is my first post here but i have been lurking about for some time and i must say the comunity here seems really good so i plan to stick around. So i guess i might aswell say hello to you here… Hello all πŸ˜„
      Anyway, back to the topic.
      Ive had this issue for quite a long time and i thought id ask if anyone else have been having the same. So to explain it simply i uploaded a screenrecording on youtube:
      [flash=425,344:3l3n9kie]http://www.youtube.com/v/1yCguEE9tjo[/flash:3l3n9kie]
      Direct link: http://www.youtube.com/watch?v=1yCguEE9tjo
      Pasted from the description i wrote:
      Im having this issue with SU hides part of my work when navigating with the orbit tool. If i move too much when it occurs all the objects stays hidden and the only way to bring them back is to close the document and reopen it again. This happens from time to time and have occured in atleast two previous versions (both SU and OS X).
      In this clip im using im using the last free version SketchUp 7 (7.1.6859) and OS X 10.6.2.
      My systemlog gives me these errors:
      " Jan 22 13:58:27 joareks-imac [0x0-0x1cf1cf].com.google.sketchupfree7[ 66000]: SketchUp(66000,0xa06e8500) malloc: *** error for object 0xa0960db0: pointer being freed was not allocated
      Jan 22 13:58:27 joareks-imac [0x0-0x1cf1cf].com.google.sketchupfree7[ 66000]: *** set a breakpoint in malloc_error_break to debug
      Jan 22 13:58:38 joareks-imac SketchUp[66000]: SketchUp(66000,0xa06e8500) malloc: *** error for object 0xa0960db0: pointer being freed was not allocated\n*** set a breakpoint in malloc_error_break to debug "
      So im kinda getting tired of this happening now and want to know if anyone else are having the same bug and knows whats causing it or fix it πŸ˜„
      • GaieusG
        Hii Joarek,
        That's the so called "Clipping issue". See if any of the suggestions work below:
        http://sketchup.google.com/support/bin/answer.py?hl=en&answer=36261
        • J
          Joarek
          Ah great, thanks alot Gai.
          I did search for some answers but it was not easy to figure out what keywords that suited the issue.
          I will try those tips the next time it happens and see if that sorts it. Cheers πŸ‘
