    View
    3 Posts 3 Posters 279 Views 3 Watching
    • N Offline
      nlin
      How to get vertical lines parallel in 2 point perspectives?
        One possibility
        Draw one then Move / copy it with Ctrl thne press * x (x as you yant)
        here x= 10
        • DavidBoulderD Offline
          DavidBoulder
          If you want them to appear parallel in your view (e.g. not converging up or down), then you need to make sure your camera is level (Camera and Target are at the same height). You can eyeball this if you just want to be close, or start with a camera that is level, and never tilt it up or down.
          David Goldwasser
          OpenStudio Developer
