    [Plugin] ExtrudeTools - Full Set
    636 Posts 178 Posters 962.5k Views 175 Watching
    • P Offline
      PeterF
      Ok, I've got the toolbar, but when I try to use the EbyEdge tool, for about 15 - 20mins nothing happens. My computer is normally quite fast - is it meant to take that long?
        Run it with the Ruby Console open and post any error messages.
        Are you sure you want to use this too?
        It has quite specific results.
        Perhaps EEbyRails might be what you want... 😕
          Hi, thanks aagain for this excellent tools
          Is it possible to use extrude edge by loft by using lines and curves instead of curves exclusively,
          If it is not possible how can I recreate the line using a curve ?
          Fredo's CurviLoft might work with plain edges... BUT most of my EEby... tools usually require 'Curves' to be selected... to make a collection of edges into a 'curve' use weld.rb, it's freely available from Smustard.com...
            altab
            I've ended using curviloft, the weld tool couldn't manage to get my lines into curves
              Meisterdrow
              I have the toolbar, but nothing happens if i want to use a function except the popup-windows.
              I am getting the following error from Ruby-Console:
              Error: #<TypeError: reference to deleted Group>
              C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/extrudeEdgesByFaces.rb:626:in entities' C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/extrudeEdgesByFaces.rb:626:in make_mesh'
              C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/extrudeEdgesByFaces.rb:286:in `onLButtonDown
              Can anyone help me? Thanks in advance!
                The error you show is when you choose to intersect the mesh with itself. What happens if you don't do that [say No!]...
                Can you post the SKP that's causing the issue and some instructions on the steps you are taking to get the error, which I can't reproduce... 😕
                  Meisterdrow
                  Hi TIG,
                  thank you for your fast answer! I will give a more detailed description: I had to reinstall Sketchup and because of that also your plugin. Since that reinstallation the whole plugin is not working anymore and I can’t figure out why (because I installed it the same way as before). No matter which function of the plugin I use, I get no result.
                  I get the error message I posted every time when I press “intersect with mesh”. When I press anything else nothing happens at all (no matter which of the functions I use). When I use the function “Extrude edges by rails” for example I get another error message:
                  EEE
                  undefined method `transform!' for nil:NilClass
                  I added two screenshots, I don’t know if that helps.
                  • majidM Offline
                    majid
                    dear Tig
                    I installed this set on a fresh copy of Su but some tool are not working with no error message! just it highlights ( and recolor) curves!
                    Majid
                      Majid
                      Have you installed all of the .rb files that are in the zipped set - e.g. the deBabelizer.rb.
                      Have you definitely installed all of the other files keeping them inside their subfolder ?
                      Are you sure it's not a 'Compatibility Files' issue ?
                      Do you have full access rights to the Plugins folder etc...
                      Are there any [other] Ruby Console messages when you try to run the tool ?
                      MeisterDrow
                      Same goes for you...
                      Can you post the sample SKP and a step by step of what you do to get the failure.
                      It may be you are trying to do something that another tool would be better suited to ??
                      • majidM Offline
                        majid
                        dear TIG, there is some other plugin installed, libfredo, scin and loft, ferrari sketch, and that is all. all of them are installed in a true way. at the moment cannot check, but will tomorrow.
                          Meisterdrow
                          Hi TIG,
                          thanks for your support, that's not self-evident!
                          You have been right, it was a 'Compatibility Files' issue as you recommended. Your plugin 20111113 is not working if sketchyphysics 3.2 is also installed. The older version of your plugin in combination with an older sketchyphysics version worked. Now I deleted sketchyphysics and your plugin is working fine! 😍
                          Greetings
                            There is a known problem with several scripts being incompatible with SP - which messes, ill-advisedly with some base-classes...
                            We await its resolution.
                            The 'Compatibility Files' often catches users out on new systems -one of Windows dafter ideas...
                            • gudio83G Offline
                              gudio83
                              Hi everybody,
                              i have installed the TIG extrusion tools, but the most of them don't work.
                              I make:
                              2 arcs, after make a groupe - it's the first groupe.
                              2 arcs for the second groupe.
                              I select the 2 groupes and start EXTRUDE EDGES BY EDGES
                              Sketchup show me : MULTIPLYING EDGES.....
                              .... waiting 5 minutes and nothing.
                              the same is with other tools
                              I have no problem with tools like ARTISAN and others
                              Where is the problem?
                                Run EEbyEdges with the Ruby Console open and post any error messages.
                                Are your arcs of a reasonable size etc ?
                                Why not post the SKP that's not working, or at least a screenshot - you might have made the bits wrongly ?
                                We can't tell unless we have more information...
                                Works for me and thousands of others... 😕Capture.PNGAre you sure it's the tool you want? If you welded the arcs into curves and the used EEbyRails would that perhaps give the expected result ??
                                • gudio83G Offline
                                  gudio83
                                  that's on ruby console:
                                  Error: #<TypeError: wrong argument type (expected Sketchup::Entity)>
                                  C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/extrudeEdgesByEdges.rb:228:in add_group' C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/extrudeEdgesByEdges.rb:228:in activate'
                                  C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/extrudeEdgesByEdges.rb:384:in select_tool' C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/extrudeEdgesByEdges.rb:384:in extrudeEdgesByEdges'
                                  C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/extrudeEdgesByEdges.rb:399
                                    Still doesn't help a lot!
                                    However, I now suspect that it's a clash with another script that's ill-advisedly interfering with the built-in group.copy method. One known culprit is Sketchy-Physics, another is Driving-Dimensions. If you have those install tools please try disabling them - to do that find the relevant .rb or .rbs file[s] in the Plugins folder, that will load the tool[s] and add a '!' to the end of the file-extension [you need your folder options set to let you see the extensions] so they are .rb! or .rbs! files. Restart Sketchup and see if EEbyEdges works now...
                                    I am looking at a workaround for this kind of issue - but it's these rogue tools who's code is wrongly messing with built-in methods though !
                                    It it continues after the disablement, then post the SKP or at the very least a screenshot, with instructions on what you pick, how etc, so we can test it ourselves...
                                      Here's an updated zipped set.
                                      http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
                                      Six of the tools that used the built-in method 'group.copy' have been rewritten to avoid using it [you will now get a warning that 'make-unique-is-deprectaed' in the Ruby Console but that's a glitch with the way Sketchup is written and not an error per se].
                                      This has been forced on us because there are still a few rogue scripts out there where the authors have messed around with some built-in base-class methods like this, and then the expected result is not returned...
                                      • gudio83G Offline
                                        gudio83
                                        It's great. all tools without EXTRUDE EDGES BY EDGES work.
                                        EXTRUDE EDGES BY EDGES still don't work. now every time tells me: select 2 groups of edges. 1st profile 2nd path.
                                        i have no idea why, there is no error message.
                                          Please post your SKP that's not working so we can see...
                                            sameer_engi
                                            i like it; it so easy to use and save time thinks 👍
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 31
                                            • 32
                                            • 14 / 32
