    Transformation Matrices, Wt and the Homogeneous Mystery
    4 Posts 3 Posters 399 Views 3 Watching
    • M
      MartinRinehart
      There are four Transformation.scaling() methods. Two of them set a global scale. The inverse of the global scale is placed in TransformationMatrix[15].
      If you have not looked, scaling through the Scale Tool is quite limited compared to what you can do with Transformation.scaling().
      Author, Edges to Rubies - The Complete SketchUp Tutorial at http://www.MartinRinehart.com/models/tutorial.
      • Chris FullmerC
        You can also use the transformation matrix to skew components, which is a transformation where the axis is changed to not be 90degrees from red to blue to green. A cube becomes a rhomboid, for example. This is not part of the scaling method, but requires manipulation of the 16 element transformation matrix.
        All my Plugins I've written
        • M
          MartinRinehart
          I've bookmarked a "how-to-skew" site, but I've not found the practical application yet. Have you?
          • thomthomT
            Components/groups end up skewed if you got them nested a couple of times inside non.uniformly scaled parents.
