    Selection of item created
    3 Posts 2 Posters 623 Views 2 Watching
    • P Offline
      Pauline01
      Re hello,
      You help me to create a groupe of entities, but i need to select automaticly this group // object after the creation because i want add an attribute with dictionnary system.
      In the code, i want select my object after the line "#i want select the item created to configure an attribute #???".
      Thx.
      require 'sketchup.rb'
      def add_etiquette
        # Get "handles" to our model and the Entities collection it contains.
        model = Sketchup.active_model
        entities = model.entities
        # Create a series of "points", each a 3-item array containing x, y, and z.
        pt1 = [0, 0, 0]
        pt2 = [30, 0, 0]
        pt3 = [30, 0, 17]
        pt4 = [0, 0, 17]
        # Call methods on the Entities collection to draw stuff.
        # new_face = entities.add_face pt1, pt2, pt3, pt4
        group = entities.add_group
        group.entities.add_face(pt1,pt2,pt3,pt4)
        #define an adress for the object in a dictionnary
        prompt = ["Name_zone"]
        val = Sketchup.active_model.selection[0].get_attribute("MyDico", "Name_zone")
        default = [val]
        result = UI.inputbox prompt, default, "Enter the Zone Name"
        adrresult = result[0].to_s
        adr = Sketchup.active_model.selection[0].set_attribute("MyDico", "Name_zone", adrresult.to_s)
        UI.messagebox ("@ ; " + adr.to_s + " saved")
      #Menu
      if (not file_loaded?("zEtiquette_config.rb"))
          tool_menu = UI.menu "Tools"
      	tool_menu.add_item("Create zone item") {
          add_etiquette
      	$VSX = Vsx.new
        file_loaded("zEtiquette_config.rb")
        You need to actually select it?
        You already have an reference to the group:
        the variable group is now referring to the group you created.
          group.set_attribute('yourDictionary', 'yourProperty', 'yourValue')
        This will set the attribute without having to specifically select it.
        • P Offline
          Pauline01
          oh! thx
