    Dimension Problem?
    8 Posts 4 Posters 324 Views 4 Watching
    • W Offline
      woodbutcher
      I have been using sketch up for a while and have started using it for woodworking designs. I have spent a great deal of time on a piece recently and when I got all finished and went back to dimension, all of the components are slightly off from when I started. I have gone back a few times and corrected, but they still are off. Is there something I am doing wrong? the dado's and plywood line up but they aren't the same dimensions I started with. I designed every piece in the cabinet as a group or model, and enter all dumensions through the keyboard, but I am very frustrated. It's mostly just a few 64th's off but it really makes it impossible to build from.
        dedmin
        Can we see the project?
        • W Offline
          woodbutcher
          Sure, I'm so frustrated.
          painted lower.skp
          • Jean LemireJ Offline
            Jean Lemire
            Hi Woodbutcher, hi folks.
            The only thing that comes to my mind is that you have the "Length snapping" turned on in the "Model info --> Units" dialog box.
            This may cause unwanted snaps to an invisible grid.
            However, you can specify exact measurements in the Dimension Box.
            Just ideas.
              Indeed, I can understand your frustration. However - from the model, at this phase, it is really hard to tell where it went wrong (Jean might be right). Better than nothing, at least I cleaned it up a bit; oriented faces correctly and close the back of the doors.
              There are some minor pieces (stripes) missing in some doors and I would use components instead of groups and the top molding is somehow running across itself in one corner but otherwise it is a nice model.
              Now back to your problem: the way you could scale the individual parts correctly is (very simply) demonstrated in this tutorial. There is however a very good plugin that would allow you to do this esily even on complex shapes: FredoScale (watch the video to see its potentials)
              painted lower.skp
              • W Offline
                woodbutcher
                I entered every dimension through the dialog box I checked the pieces a bunch of times as I went and it seemed like at the end I went back and the most basic measurement, like the box being 87.5" long was way off. i drew stiles and rails through the dialog box and they are almost all off. I can't understand the benefit between using components versus groups. Any suggestions? Ohh one more thing. what could I have done through the process that would have resized my pieces?
                  That's what I cannot really imagine. Unless you incidentally scaled something with the Tape measure for instance?
                  • Once you have a component definition in the model (and no matter how many instances of this same component), SU will always calculate its whatever complex geometry once thus you can save file size.
                  • Whenever you modify any of these instances, all the other instances will immediately reflect these changes (now imagine texturing these doors one by one - or all at the same time).
                  • You can export and reload components from/into your model (so if you still had these as separate files, now you could simply reload them).
                  • W Offline
                    woodbutcher
                    that's it. I know it, when I got close to finishing I was messing with resizing the cabinet door to fit the opening from the original drawing, I bet i screwed something up with that. I'm sure that's it. I was so careful to check and recheck my dimensions as I was drawing. everything is off, but the panels still fit the dado and that would make sense it I scaled the model by accident. I will sleep so much better tonight.
