    πŸ”Œ Easy Offset | Offset selected faces in SketchUp in positive and negative offsets. Download
    Code Profiling
    28 Posts 8 Posters 4.7k Views 8 Watching
    • W Offline
      Whaat
      get started with that link, makefiles are peanuts compared with COM and finding problems in RubyInline πŸ˜‰
      Thanks! I will definitely try this at some point.
      So, other than having full Ruby installed and a development environment such as PellesC, is there anything that needs to be done for this to work?
      I would still love to see an actual SketchUp related example where you pass values from Ruby to the C extension and then back again.
        todd burch
        If you ever saw SimuTerra, that was an an app that was made into a C extension from Ruby. As far as I am aware, it suffered from none of the issues mentioned by Adam. It was blazingly fast to manipulate terrains with SimuTerra. (sp?)
        • tbdT Offline
          tbd
          Whaat: I created a simple extension that creates a class SUExt with method add which adds 1 to the input at http://bitbucket.org/tbd/suext/src/
          there are no error checking and it is a minimal example that compiles with PellesC (free C compiler) and it can be used in SketchUp
          have fun
          SketchUp Ruby Consultant | Podium 1.x developer
          http://plugins.ro
          • W Offline
            Whaat
            have fun
            Thanks so much for taking the time to do this!
              tomasz
              +1!
              Author of [Thea Render for SketchUp](http://www.thearender.com/sketchup)
                Jim
                I thought you were a github man?
                • tbdT Offline
                  tbd
                  I like more github as a repository site but I like even more Mercurial as DVCS πŸ˜‰ and I was lazy to create a bridge to git using hg-git
                  http://plugins.ro
                    Jim
                    I tried once to see it was possible to use the same folder for both systems. I just set each one to ignore the repos and configs of the other. It appeared to work; at least in my simple test folder.
                    I tried and hg-git also, although it took some extra installation and setup. It also seemed to work just fine, although I had more warnings than I cared for - made me nervous.
                    • 2 / 2
