    Code Profiling
    28 Posts 8 Posters 6.1k Views 8 Watching
    • W
      Whaat
      Would anyone be willing to provide a code snippet showing a trivial example of using C in combination with Ruby? I am still feeling kind of lost about how I could pass information back and forth between the two languages.
      • tbdT
        tbd
        Whaat: a ruby c extension or a SU SDK one ?
        http://plugins.ro
        • W
          Whaat
          Whatever is the simplest.... ๐Ÿ˜„ Even a 'hello world' example would be a good start.
          • tbdT
            tbd
            the simplest is ruby extension and I showed you a link some time ago. didn't worked ?
            to use SU SDK for a simple .skp page parser I made a small 8kb exe that needed 8.92 MB of .DLL files ๐Ÿ˜ฎ
            http://plugins.ro
            • W
              Whaat
              Heh...I never tried it because I got scared of the makefile stuff...
              What interests me much more is Rubyinline. Look at the comment posted just below the blog post at the link you are referring to.
              Do you think Rubyinline can be used with SketchUp? I see that it requires rubygems so this (and Rubyinline) would have to be distributed with the plugin as I see it.
              • tbdT
                tbd
                no. RubyInline is just a shortcut for building extensions - you still need to have a compiler on that machine to make it work.
                I also had problems make it run on my Windows machine as it doesn't like paths with spaces (v 3.6.3) and also it uses deprecated options for VC.
                get started with that link, makefiles are peanuts compared with COM and finding problems in RubyInline ๐Ÿ˜‰
                http://plugins.ro
                • W
                  Whaat
                  Thanks! I will definitely try this at some point.
                  So, other than having full Ruby installed and a development environment such as PellesC, is there anything that needs to be done for this to work?
                  I would still love to see an actual SketchUp related example where you pass values from Ruby to the C extension and then back again.
                  • T
                    todd burch
                    If you ever saw SimuTerra, that was an an app that was made into a C extension from Ruby. As far as I am aware, it suffered from none of the issues mentioned by Adam. It was blazingly fast to manipulate terrains with SimuTerra. (sp?)
                    • tbdT
                      tbd
                      Whaat: I created a simple extension that creates a class SUExt with method add which adds 1 to the input at http://bitbucket.org/tbd/suext/src/
                      there are no error checking and it is a minimal example that compiles with PellesC (free C compiler) and it can be used in SketchUp
                      have fun
                      http://plugins.ro
                      • W
                        Whaat
                        have fun
                        Thanks so much for taking the time to do this!
                        • T
                          tomasz
                          +1!
                            Jim
                            I thought you were a github man?
                            • tbdT
                              tbd
                              I like more github as a repository site but I like even more Mercurial as DVCS ๐Ÿ˜‰ and I was lazy to create a bridge to git using hg-git
                              http://plugins.ro
                                Jim
                                I tried once to see it was possible to use the same folder for both systems. I just set each one to ignore the repos and configs of the other. It appeared to work; at least in my simple test folder.
                                I tried and hg-git also, although it took some extra installation and setup. It also seemed to work just fine, although I had more warnings than I cared for - made me nervous.
                                • 2 / 2
