    Don't name a method "next"!
    9 Posts 5 Posters 831 Views 5 Watching
      MartinRinehart
      Here is bug_splat.rb, which does as its name suggests when you try to load it.
      def bug_splat()
          next()
      Edit: typing next() into the Ruby Console gets a Bug Splat.
      Author, Edges to Rubies - The Complete SketchUp Tutorial at http://www.MartinRinehart.com/models/tutorial.
        Jim
        Hey cool, it "works" the same if you just type it in the Ruby Console.
        next does not bugsplat, next() does.
          next is a Ruby reserved keyword used to control loop iteration.
            Jim
            next is also a method meaning "give me the next value."
            1.next ==> 2 "a".next ==> "b"
              MartinRinehart
              Some languages handle the misuse of a reserved word with a bit more grace.
              • Chris FullmerC Offline
                Try it from the rerula - non SU ruby command line editor. I doubt it will give a bugsplat 😄 Maybe it just returns an error, or critical error or something.
                All my Plugins I've written
                  Good point. But that leads to the question; is "reserved" really reserved in Ruby?
                  So next can be class method, but not a root method?
                  • tbdT Offline
                    tbd
                    let's see (Mac, ruby 1.8.6, command line)
                    irb >> next()
                    LocalJumpError; unexpected next
                    	from /System/Library/Frameworks/Ruby.framework/Versions/1.8/usr/lib/ruby/1.8/irb/workspace.rb;81;in `evaluate'
                    Maybe IRB bug!!
                    ruby -e "next()"
                    -e;1; unexpected next (LocalJumpError)
                    so it is more a ruby problem than a SU. but why the exception is not trapped by SU ?
                    SketchUp Ruby Consultant | Podium 1.x developer
                    http://plugins.ro
                      Windows7, Ruby 1.8.0 - Console Session (IRB)
                      C;\Users\Thomas>irb
                      irb(main);001;0> next()
                              from C;/Ruby/lib/ruby/1.8/irb/workspace.rb;81;in `evaluate'
                              from C;/Ruby/lib/ruby/1.8/irb/context.rb;219;in `evaluate'
                              from C;/Ruby/lib/ruby/1.8/irb.rb;150;in `eval_input'
                              from C;/Ruby/lib/ruby/1.8/irb.rb;263;in `signal_status'
                              from C;/Ruby/lib/ruby/1.8/irb.rb;147;in `eval_input'
                              from C;/Ruby/lib/ruby/1.8/irb/ruby-lex.rb;244;in `each_top_level_statement'
                              from C;/Ruby/lib/ruby/1.8/irb/ruby-lex.rb;230;in `loop'
                              from C;/Ruby/lib/ruby/1.8/irb/ruby-lex.rb;230;in `each_top_level_statement'
                              from C;/Ruby/lib/ruby/1.8/irb/ruby-lex.rb;229;in `catch'
                              from C;/Ruby/lib/ruby/1.8/irb/ruby-lex.rb;229;in `each_top_level_statement'
                              from C;/Ruby/lib/ruby/1.8/irb.rb;146;in `eval_input'
                              from C;/Ruby/lib/ruby/1.8/irb.rb;70;in `start'
                              from C;/Ruby/lib/ruby/1.8/irb.rb;69;in `catch'
                              from C;/Ruby/lib/ruby/1.8/irb.rb;69;in `start'
                              from C;/Ruby/bin/irb;13
                      Maybe IRB bug!!
                      irb(main);002;0> exit
                      C;\Users\Thomas>
