    How would you modelling this... Photomatch? [TUTORIAL]
    7 Posts 3 Posters 791 Views 3 Watching
    • utilerU
      utiler
      Hi guys,
      A mate of mine wants to know if i can model this chair for him.
      As you can see i have started it but because there is so many curves and the fact that I don't know the sizes is stumping me....
      Should I continue with PhotoMatch and try and scale it once it's close?
      Would you draw curves with simple arcs then weld together or try Bezier curves...?
      Any suggestions would be much appreciated!!
      See attached Skippy and image...
      πŸ˜‰
      cotswoldChair.skp
      Just Curious...
      • D
        dedmin
        More to finish
        • Mike LuceyM
          Mike Lucey
          Andrew,
          I looked at your WIP and it looks to me that you are 80% there. The attached pic does show the construction of the overall lazy chair which is great.
          I think its a matter of 'cobbling' the whole thing together via PM and straight SU work. You will have to approximate the overall size, probably based on typical timber thickness that would be used to this type of chair, 3/4" (I imagine) and the use of standard widths, in this case I again imagine 24".
          The interesting features to replicate are the joints and dowels used, very interesting indeed. I think you should also use edited wood texture from the pictures for the finished SU model.
          Not much help I am afraid.
          Mike
          • utilerU
            utiler
            Thanks guys.
            Dedmin, can you elaborate a little on how you modeled it? Looks like a nice copy.....
            Mike, that's pretty much how I was going to attack it and scale it to suit a typical furniture grade size as well as some simple anthro measurements....
            Thanks for the comments, will post progress.... πŸ‘
            Just Curious...
            • D
              dedmin
              First, decide on the build dimensions and then paste the picture and scale it to fit to this dimensions. Trace over using Catmull spline toll, push-pull, make components.
              Chair.skp
              • utilerU
                utiler
                Thanks mate, nice tut!!! might give it a go....
                much appreciated. πŸŽ‰
                Just Curious...
                • D
                  dedmin
                  Finished model
                  http://forums.sketchucation.com/viewtopic.php?f=40&t=25129
