    Moving Smoothly
    7 Posts 5 Posters 684 Views 5 Watching
      MartinRinehart
      I want to move things smoothly. I'm experimenting with thread functions, so far without success. In the sample code, I added a sleep( 1 ) to a move/copy routine, hoping to see copies added at 1 second intervals. What I see is a long wait and then everything appears at once.
      def move_copy( component, distance, number_of_copies )
      =begin
      Creates an outer array, moving a component "distance" as many times as specified.
      "distance" is a vector, an array of [r, g, b].
      "number_of_copies" is like the "Nx" in the VCB after a Move/Copy.
      For 15 steps, you make 14 copies.
      =end
      	ents = Sketchup.active_model.entities
      	defi = component.definition # the original component's definition
      	trans = component.transformation # the original's transformation
      	pt = trans.origin # the original's location, a Point3d
      	for i in ( 1..number_of_copies )
      		pt += distance
                  # add vector to Point3d getting new Point3d
      		trans = Geom;;Transformation.new( pt )
                  # create new Transformation at the new Point3d
      		ents.add_instance( defi, trans )
                  # add another instance at the new Point3d
              sleep( 1 )
      end # of move_copy()
      Ideas?
      Author, Edges to Rubies - The Complete SketchUp Tutorial at http://www.MartinRinehart.com/models/tutorial.
        Jim
        Use the Animation class. Or a timer.
          Jim
          Or a frame change observer to animate entities a'tween scenes.
          Some plugins that use these techniques:
          • Proper Animation - morrisdov
          • mover - cmd
          • mover modified with easings and dialog
          • SketchyPhysics
          • animation.rb - @last
          • animation2.rb - @last
          • animated clock - todd burch
          • transformer beta - didier bur
            avariant
            Maybe the view just isn't refreshing on each iteration? Try adding a view.invalidate of view.refresh before each sleep.
              MartinRinehart
              @jim said:
              Or a timer.
              Thanks Jim. Lininger's piece has me moving smoothly.
              Thanks. invalidate() didn't work but refresh() worked, tho not so smoothly.
              • Chris FullmerC Offline
                Don't forget that refresh is new to 7.1 (or was it 7.0?). Anyhow, it is new and not compatible with older versions...
                Chris
                All my Plugins I've written
                  Chris
                  7.1
                  http://code.google.com/intl/nb/apis/sketchup/docs/releases.html
