    Dome with smooth edges
    29 Posts 9 Posters 4.8k Views 9 Watching
      d12dozr
      I do this a lot , if that's what you mean
      And just HOW do you do that? 😄 I believe that is what he means...
      http://goo.gl/f7ooYh
        driven
        probably the hard way,
        I strip out the annular rings from one sphere, make a group, rotate copies until I like the pattern, explode the lot, slice off the top (3 or 4 rings), drape with sandbox, slice off the top of a plain old 'follow me' sphere (just 1 or 2 rings), offer up the sandbox hat (Gai was right, just a hat), decide how far to use the pattern, trim, explode, add projected material off a number of different angled surfaces I paint ( and make unique before projecting), decide what I like, purge all the test materials, and that's it...
        I make these cages for pipe along path objects, and just thought I try draping and rendering one night,
        foolishly I always bin the makings and have to start from scratch each time, but I'll keep this drawing and use it as a component, nearly everything is grouped so have a play.
        like this
        You only need to change the top 1 or 2 rings to completely change how the texture gets projected, but I have no idea why.
        On this one I also copy pasted the cylinder off the standard one because the texture worked better on that one, again no idea why.
        john
        this is why I normally use this technique (it's for a 3D printing test in stainless steel)
        I haven't cleaned this up, but should be OK
          d12dozr
          Thank you for the detailed explanation.
            driven
            no problem, don't know if it helps Al (I know next to nothing about UV mapping, but I just saw this sitting on the desktop and may as well add it
            I think explains the basic construction technique more clearly
            • Al HartA Offline
              Al Hart
              I finally found geodesic_sketchup.rb script on
              http://www.crai.archi.fr/rubylibrarydepot/ruby/em_geo_page.htm
              It created a spehere with even triangles, so the material does not bunch up at the top or bottom. Now I just need to find a pattern which is tileable in a triangular pattern. (I turned on the hidden lines here so you could see the actual triangles which form the sphere)
              Here's what I was trying to get - a sphere which would take a bumpy pattern, and spread it out well.
              Al Hart
              IRender nXt from Render Plus
              • TaffGochT Offline
                TaffGoch
                Hello, all,
                I've been "lurking" on this discussion, and see that Al has posted an image of Simon Thomas' sculpture, "Orb"...
                http://plus.maths.org/issue8/features/art/orb.jpg
                As Gaieus mentioned, it is, indeed, based on a geodesic sphere (class-I, frequency-2, if you're familiar with the terminology.)
                Several other of Thomas' sculptures are compelling, and would make for interesting SketchUp exercises.
                http://plus.maths.org/issue8/features/art/hc4.jpg
                http://plus.maths.org/issue8/features/art/hcone1.jpg
                See here, for descriptions: The art of numbers
                For geodesic design in SketchUp, I often use an online java applet that can output a text file of the x,y,z coordinates for each vertex, which I then import into SketchUp, as a "point cloud"...
                Thomson Problem
                ...just another (powerful) geodesic resource, should you be looking for such.
                Taff
                "Information is not knowledge." -- Albert Einstein
                  driven
                  one of Geoge W Hart's downloadeable STL files
                  http://www.georgehart.com/rp/rp.html
                  You might try skinning one of the models on this site, well worth a visit in any case
                  john
                  • Al HartA Offline
                    Al Hart
                    I added a dome and sphere to RpTools using Gavin Kistner's Geodesic class.
                    This should make it much easier for me to create smooth domes and sphere when I need one.
                    Al Hart
                    • Al HartA Offline
                      Al Hart
                      Thanks for everyone's help on this issue.
                      What this was all about, is that I wanted to show the effect of using a 360 Panaromic HDRi image as background for rendering, and a smooth dome makes it easier to see how the HDRI is reflected. I wanted a good tool to make a quick, smooth dome - especially for reflection examples.
                      The image below uses a Free HDRi provided by Bryan James. He made a 360 photo of the interior of St. John's Cathedral in NYC. The Sketch Up model is a reflective ground plane, and a reflective dome.
                      Everything else is generated using the HDRi for lighting, shadows, background and reflection.
                      Al Hart
                      • 2 / 2
