    Exporting help
    2 Posts 2 Posters 228 Views 2 Watching
    • R
      Rominzxx
      Yes well when i export a model in .3ds format it has no textures. Im exporting because Metasequoia cant read .skp. When i convert everything is fine except for the textures. The only reason why i need to edit in Metasequoia is because im using this for a game is play. Any help? Im trying to get the textures.
      • GaieusG
        Hi Romin,
        There can be several causes for a 3ds file not exporting properly.
        Make sure that all faces you apply the materials are front faces (whitish) not back faces (bluish-grey). Then also, make sure that your material names do not contain any other characters than the English ones (not even spaces are allowed) and they are only 8 character long with the three character extension (I doubt you can remember when every file had this limitation).
