    Exaggeration Factor?
    2 Posts 2 Posters 342 Views 2 Watching
    • R
      rickgraham
      Hi all,
      I have a surface created from imported AutoCAD lines. I push/pulled all the lines up to the proper elevation. Now I am asked to make this surface exaggerated so that the the contours look greater than what they actually are.
      Right now the contour interval is 1', which on a large scale, looks relatively flat. Is there a ruby/method, etc. that will allow me to pick the entire surface and push-pull to achieve, say 5' intervals.
      This will achieve a much hillier plan, but the contour elevations will be able to be seen by the client.
      I hope I'm explaining this correctly.
      Thanks,
      Rick
      • GaieusG
        Hi Rick,
        How about scaling by 5 along the Z axis?
        Update: group it first so if eventually you need it to reset, just right click and reset scale
