    Alt...about center...ignores preserve scale setting
    Scheduled Pinned Locked Moved LayOut Bug Reporting
    layout
    10 Posts 4 Posters 10.5k Views 4 Watching
      Charlie__V
      Maybe it is performing as intended, but......if I resize .skp in LO with any other resize functions, & preserve scale on resize is ticked.........model scale is maintained as expected.
      However, if I resize about center [alt function] the model will not maintain scale.
      Bug/Feature?
      Best,
      Charlie
        Charlie__V
        Just that I am Curious....anyone else experiencing this?
        Perhaps I did not describe accurately the problem?
        Thanks to any/all response.
        Best,
        Charlie
          Hi Charlie,
          Keep the Shift key pressed (together with the Alt key) as well to scale proportionally.
          I was actually curious because there used to be such a bug (well, a bit similar - it seemed to scale proportionally but when I released the cursor, it "jumped" to a non proportional scale) but that was ironed out during some tests of LO 1 more than 2 years ago. First I was surprised it is back but no, with the Shift key, it works nicely.
            Charlie__V
            Thanks Gai,
            Scaling as you describe is noted....thanks.
            But please bear with me, what I experience is scaling up/down when that is not what I desire.
            IE:
            In LO I wish to resise a SU model "window" about center and maintain the set (current)scale of the model.
            I have maintain scale on resise ticked.......but if I resise the "window" with the alt button the model will also resise!
            My understanding is this should not happen.......Y/N?
            Best,
            Charlie
              True. There is even a "Preserve scale on resize" checkbox in the SU dialog and despite I check it, it does not preserve the scale.
              Definitely a bug.
                jhauswirth
                I created a bug-
                2368695 Alt...about center...ignores preserve scale setting for SU model
                Thanks for reporting the problem.
                  Thanks Jeff! πŸ‘
                    Charlie__V
                    10-4.....Thanks Gai & Jeff
                    Best,
                    Charlie
                      Charlie__V
                      @jhauswirth said:
                      I created a bug-
                      I could have sworn this bug was fixed a few iterations back.......No?
                      If it was....FYI: Current LO build (Version 3.0.16846) exhibits the same problem previously reported/fixed.
                      Best,
                      Charlie
                        marcdurant
                        Hi Charlie-
                        Sadly no, this one hasn't been fixed (as of v2013), but it hasn't been forgotten.
                        thanks,
                        Marc
