    Can not see edges/lines
    7 Posts 2 Posters 565 Views 2 Watching
      mustwakeup
      Hello
      I'm learning SU 7.1. When I export a section or a perspective in dwg / dxf jpeg or in another format, some lines/edges do not appear and the section it´s wrong/incomplete. I have tried the boundig edges together with soften edges and I can not see the lines in Su and therefore in the sections do not appear this lines.
      Any suggestions? There are any plugin to make again see this lines.
        Hi and welcome to the forum!
        I cannot really follow what you are trying to explain. Could you attach some images (or maybe a model) to better explain the problem?
        Also, what were you trying to link to? It's like you copied the url while you were posting.
          mustwakeup
          Thanks for the quick response.
          As you can see in the images, any face of Su that has lines when converted in dwg / dxf or jpeg does not appear.
          When I make a section is the same thing, as evident.
          I do not know how the lines of the faces disappeared.
          This it´s my ground floor, in the other floors this occur sometimes, in some faces/lines.
          What is certain is that I have ever experienced (right-click, select, bounding edges, soften edges) and the sides / lines no longer soften but do not become visible, as shown in the photos.
          If i can not do anyhing, there are some plugin who help me?
            Yes, I can see that something strange is going on. Could you share the model (or at least a part of it)?
            Also, try to go to Window (menu) in SketchUp > Preferences > OpenGL tab and disable (uncheck) hardware acceleration to see if it's a video card/driver issue on your machine only.
              mustwakeup
              Hello again!
              I did the whole model always with disable hardware acceleration unchecked only fast feedback checked.
              I send you the model complect of my school work because I am sure you or someone they will achieve a solution, perhaps in time to get even deliver the work in the coming days.
              My laptop has a sis M712, which is bad, but tried on another computer of a colleague with a better video card and the result was the same.
              But we thinks, after the model being built, whatever the computer you try, the result is always the same.
                mustwakeup
                Hello again!
                Like my father said "those who do not know is like do not seen", as I had said I am learning; I already solved the problem; the lines was in another layer. Be careful with layers.
                  Look, we had been begging to you to share that model. It may have been solved very soon.
