    HTML export with hotspots?
    4 Posts 3 Posters 410 Views 3 Watching
    • F Offline
      fredrikarvas
      Dear Forum,
      I am building a museum (virtual.vrouwmaria.com) where I have used .jpg-exports from views in Sketchup with html-image-maps to navigate between the pages.
      What I now would like is "view-spots" inside my model, where each wiew-spot would export in 4 different views (the image-export can be done with the http://www.smustard.com/script/CubicPanoOutCubic-script). In these views, with clickable-html-based image-maps would lead the visitor to the next view, like walking inside our museum.
      The best would also to use CSS-based-maps instead of html-based maps see: http://virtual.vrouwmaria.com/open/000_Exterior.html (Which I have created with http://www.image-maps.comfor refernces).
      If this script does not exist, what is the cost for develloping it?
      /Fredrik
      • Dan RathbunD Offline
        Dan Rathbun
        You should post this request in the Developers Fourm
        I'm not here much anymore.
          Hi Fredrik,
          These hotspots are possible to create outside SU (as when you have exported your view, you are already out of SU anyway) in QuickTime (where you can use that cubic panorama anyway). Or in fact in other applications that can handle panoramas and clickable hotspots like Java or Flash.
          But it is not inside SU.
          • F Offline
            fredrikarvas
            Thanks for the replys.
            I have now posted an updated question in the Devellopers Forum.
            http://forums.sketchucation.com/viewtopic.php?f=180&t=24770
            /Fredrik
