    From sketchup to UDK
    13 Posts 5 Posters 8.7k Views 5 Watching
      amigoface
      hi i am using sketchup v6 (personal version) and i try to export models to UDK (Unreal Development Kit) http://www.udk.com/
      for that i export to the kmz v4, extract it and in udk import the .dae that is inside
      the problem is that i have several meshs inside the file when trying to import instead of one
      my question is how to join all the meshs in one like the blender join operation ?
      ps : the models are from internet not from me
      thanks and good day
      • numbthumbN Offline
        numbthumb
        Hello,
        I havenΒ΄t tried it myself, but since I am interested in virtually everything that has something to do with exporting from SU to some kind of game engine, I have stumbled upon this - a UT3 export plugin for the free version of SketchUp. The author of the plugin has updated it to export T3D, ASE, PSK and OBJ files.
        http://forums.epicgames.com/showthread.php?t=615742
        Check it out and see if it helps.
        Cheers!
        Comfortably numb...
          amigoface
          hi
          i have tried several options(ase/obj/td3) including the link you give me
          from memory this one crash UDK while imporing
          other exporter like .ase don't give me the correct materials count
          the only relatively "working" option i found is the kmz4->dae way
          but like i said before the result is several mesh instead of one
          i am a begginer to skechup
          so how to group the mesh inside sketchup into one before exporting ?
          i tried making groups/components without succes
          thanks
            Hi guys,
            I have no clue about this application but there is a plugin at Smustard - GroupByTexture - which... well... does what its name says and mightbe useful in your case.
              amigoface
              ok thanks i will give it a try
              i have another general question :
              what means groups/components in sketchup ?
              whta the difference between
                Practically, as they "work" in the model, they are pretty much the same. They both are to keep a certain set of geometry together (and prevent interaction with other geometry - i.e. separating it - just like in some applications layers do but not in SU)
                Components have some extra features like:
                • you can set the axis of a component
                • you can save it as a separate skp file (which it is actually) and reload it from an external source
                • there are component definitions and instances in a model - if you change the definition (i.e. edit any instance of the same component), the changes will be reflected on all other instances
                • SU only keeps the definition (geometry, textures etc.) of a component once in its file so it is also good to keep file size down
                • etc...
                • EscapeArtistE Offline
                  EscapeArtist
                  I thought I'd give this a try and see what happens. Unfortunately, it leaves a more complex model full of missing faces and materials, not quite as badly as the obj exporter.rb that has been floating around or a while (I can't get it to work at all).
                  What still works best is to extract the .dae from a .kmz and import that to Blender, and you can export from there into the .ase or whatever other format with a plugin; though I must say it imports quite a mess of triangulated faces, and if you want quads you're out of luck.
                    amigoface
                    thanks a lot
                    see u later
                      amigoface
                      @EscapeArtist : i did'nt see your post πŸ˜„
                      i tried like you said kmz->dae-> blender
                      but it give me a blank model πŸ€“
                        EscapeArtist
                        Rename the file.kmz to file.zip. Open the file and find the .dae file (file.zip/models/file.dae). Get Blender (if you don't already have it) and use the Collada import. (File > Import > Collada 1.4) Import the file.dae.
                        Also, make sure there are no groups or components in your model. All groups and components must be exploded, otherwise you will get nothing when you import.
                        This should work, but as I said, it makes quite a mess of things and may not be worth your while to fix it. Too bad Blender doesn't have options to make it exactly like SU as far as initial modeling, it'd make Blender much more popular.
                          amigoface
                          hi
                          @EscapeArtist : it worked !!!
                          i have exploded all in sketchup, exported to kmz4,
                          and in blender imported the .dae inside it
                          however the model is extremelly large so i have modified some properties
                          http://www.katsbits.com/htm/tutorials/sketchup_converting_import_kmz_blender_advanced.htm
                          so i have now my model correctly imported and textured in blender β˜€
                          now the problem will be how to export it correctly into UDK
                          but this is another question πŸ˜‰
                          ps : any udk users here ?
                            amigoface
                            finally i get my models into udk with the right blender/plugins versions πŸŽ‰
                            they are not perfect but just fine
                            thanks
                            • E Offline
                              eaglevision
                              From my experience on importing Sketchup models to CE2 via collada, the problem with glitches on the models come from exporting an untextured model. This can be solved simply by applying a texture to every visible face of the model, easily done if all its faces are connected, you press shift + LMP while applying a texture and all the faces will be textured. After that there should be no problems.
