    Trouble with DC Constraints
    2 Posts 1 Posters 1.1k Views 1 Watching
      sdaDave
      Thanks for any help you might be able to provide.........
      I have built a DC Component for window trim for a single window, all works fine.
      I have built a DC Component for window trim for a Double window, all works fine.
      Here is the issue, when placed by them selves they work fine, when place together
      the second component will pull information from the first component, and then the
      calculations turn red and the component is not regenerated correctly.
      thanks for any help
      David
      Style A Single Window Trim.skp
      Style A Double Window Trim.skp
        sdaDave
        Just to clarify, the constraints of single window have be replaced
        by the constraints of double window, thanks again
