[Request] Select edges with material
I have a problem with deleting some materials that SU says are still in use.
Most often I think some edges have the material applied to them.
Is there a script that lets you select edges with a certain material so you can fix them or delete them to be able to remove the material? -
Doesn't remove specific materials, but let you remove all material from all edges: http://forums.sketchucation.com/viewtopic.php?f=323&t=17587
I could add Select by Material to my Selection Toys.
Thanks!
[Request] Select triangulate edges
Use Cleanup: http://forums.sketchucation.com/viewtopic.php?f=323&t=22920
Plugins->Cleanup->Select Coplanar Edges -
I'm using version 1.1.2, I couldnot see the Select Coplanar Edges
oops... seems that I changed that... I'll add it to the list.
Thank you ,thomthom
http://forums.sketchucation.com/viewtopic.php?f=323&t=24635
Register LoginAdvertisement
