    [Podium] Omni & Spot Lights creation in Podium 1.x
    extensions
    10 Posts 3 Posters 1.1k Views 3 Watching
      For make your own lights! πŸ˜„
      Of course it's only the light! πŸ˜’
      You must make the blister or your own volume design around it if you want! πŸ˜‰
      Click image for Zoom
        sepo
        Great but all in French. Did you plan it for French Subforum?
          Ah yes, sorry, I will make the same for the English part! 😳
          Give some minutes πŸ˜‰
            sepo
            Yes of course...but you are aware that lights are created differently in V2.
              Yes, it's for the Podium 1.x πŸ˜„
              • honoluludesktopH Offline
                honoluludesktop
                Pilou, What is the function of the line?
                  honoluludesktop
                  I can not see your image?-). Does it matter if the line is not perpendicular to the face of spot?
                    Yes orientation, direction, length are important πŸ˜‰
                    Here power light are the same!
                    click if scroll bar
                      Spotlights can be used to manipulate light falloff. The falloff is determined by the length of the line drawn out from the group
                      πŸ˜‰
                      For a same power of light you can have that for example
                      My spotlight is inside the cylinder wihout downcap, on the left line is equal to the cylinder
                      On the right line is quasi null
                        honoluludesktop
                        Thanks, wounder what v2's light fixture attributs will be like.
