    Copy Catting
    36 Posts 21 Posters 3.1k Views 21 Watching
      Crazy Eyes
      My Dad recently moved to a different country. He now has a new job as chief designer in an architectual firm. He wants me to keep doing models for him so he sent an example of what his new boss considers a good render.
      AutoCad Revit
      So I spent an hour making a model of the scene
      Raw SketchUp
      and then rendered it in several different renders to compare them.
      HyperShot
      Twilight
      Vray
      Mine are not as good, but I think I made progress.
      Vray with Displacement
      I know that most of you can do a lot better, so C&C's are more than welcome.
      If you want to here is the file:
      Test.skp
      Some people are lovers, some are fighters, if you love to fight, fight for love!
      • FrederikF Offline
        Frederik
        The Twilight Render doesn't look particular good, but I assume that it's almost default settings that have been used, which really doesn't compliment the TWR capabilities...
        The V-ray renders look much better, because you know what you're doing... 😐
        It also looks as if there's no soft shadows in the V-ray renders... πŸ˜•
        Cheers
        Kim Frederik
        • olisheaO Offline
          olishea
          im quite impressed with hypershot version, nice mood to it. if you spent 5 minutes setting up materials/environment with twilight it would be instantly better than cad version.
          oli
            dspace
            The hypershot was render with HDR and the others very differently with Sun + Physical Sky. I think that made the big difference and an unfair comparison IMHO. πŸ˜‰
              bytor
              CE,
              I couldn't resist playing with the twilight version just a little while on lunch break here @ work. Just some minor tweaks (3-4 minutes total) to the materials and a quick run through easy #7 setting get's you here. I don't like the water, but I think this clearly shows that just a little playing with the materials in twilight gives the image (no pp like yours) much better definition and depth.
              JMO
              Bytor
              Find the Cost of Freedom.....
                d12dozr
                Nice job, Bytor....I also used Twilight - I used a HDR from the Twilight team, mostly materials from the generic templates, and rendered with Medium+ in less than 4 mins with my sloooow laptop πŸ˜„ I added some grass in Photoshop for the 2nd image.
                ---10 min material setup, 4 min render, 5 min PP---
                Straight Twilight Output
                Grass added in Photoshop
                http://goo.gl/f7ooYh
                • soloS Offline
                  solo
                  A quick render with Vue (6m 34s), setup about 10 minutes, no post processing
                  http://img7.imageshack.us/img7/3039/copyscf.jpg
                  http://www.solos-art.com
                  • EscapeArtistE Offline
                    EscapeArtist
                    Kerkythea, MLT/BPT with provided textures unchanged and not adjusted. Added sky.
                      bytor
                      Pete,
                      The "growies" in Vue are jsut outstanding! πŸ‘
                      • RichardR Offline
                        Richard
                        @bytor said:
                        Pete,
                        ABSOLUTELY!!!!!
                        [BUILTBRAND.COM.AU](http://builtbrand.com.au/)
                          dspace
                          Outstanding! πŸ‘
                            Luis Esteves
                            Good day everybody,
                            Here is my render with VRAY.
                            The "Size Multiplier" parameter (in GI (Skylight)) has been increased to 10 to get softer shadows.
                              Crazy Eyes
                              Wow! Everyone!
                              I wasn't expecting such a response from all.
                              Solo, you are my inspiratoin, and I was sincerly hoping you would give an example from Vue, truely outstanding.
                              I thought I would try it myself too. Thing is though that I couldn't seem to get the ambient lighting working very well. Any suggestions? Today is the first day I've had a play with it, so unless it's simple to fix, don't bother even trying to explain to me :S
                              Vue8
                                Okay, here is my "quick and dirty" test (I can make "dirty" renderings only anyway). The choice of the sky was probably a bit of a mistake (too bright, too blue) and I have obviously screwed the shrub on the right.
                                Otherwise (except for Majid's water and the warped thin glass which is "shipped" with Twilight) everything is the original in the model and I only used the pre-set templates to quickly adjust the materials.
                                • soloS Offline
                                  solo
                                  Go into atmosphere editor, in the 'Light' tab select 'GR' that will make the atmosphere Global radiosity (make sure both options below it is also checked)
                                    OK, another try with some further tweaks (modified shadows for instance to get some more exciting variations of hard(er) and soft shadows - changed plants, added something behind the camera so that the window can reflect it...)
                                    • RichardR Offline
                                      Richard
                                      Maxwell, noisy!! Only 40min on my crap top! All mats straight from crazy's file but grass, glass brick and gal steel. 5 min PP
                                        sepo
                                        Nice ...Richard. How long would take Maxwell to clear that noise as it is quite noisy?
                                        • RichardR Offline
                                          Richard
                                          Mate as mentioned it was rendered on a 2.4g dual thread, not dual core even! Plus I added a lot of geo in plants, about twenty clipped trees and an internal emitter. So it's probaly not a good example. Though 2-3 hours at that res would clean it up well, done with 1.7.1 - V2 by all accounts is much faster and if I had taken the time to open it in studio you have the option to save out your physical sky as HDRI. You can then just plug that straight back in and it would rip through again much quicker!!
                                          I'd say if I had an i7 and used HDRI it would render clean and twice the res in an hour!
                                          You have to say though that Maxwell's lighting is hard to beat!
                                            sepo
                                            Yeah the lighting is nice but that noise is problem for me. It is like watching paint to dry. πŸ˜‰
                                            • 2 / 2
