    Worn medieval cobble street
    5 Posts 4 Posters 1.1k Views 4 Watching
      Anyone got some good textures of medieval cobble streets. Or something that looks to fit into a scene of a busy medieval street?
      No need to be tiled, just nice samples I can stitch together in the foreground of a render I'm working on.
      • soloS Offline
        solo
        Why not use geometry?
        If it's foreground then you would like the shadows and all, nothing tops the real thing IMO.
        http://www.solos-art.com
          hmm...
          It's for this scene: http://forums.sketchucation.com/viewtopic.php?f=81&t=18393&st=0&sk=t&sd=a&start=45#p154693
          The way I imagine it, AM is pretty busy, so there's a lot of wear and tear on the streets. In most streets I'd think it'd be dirt, but this is right about the centre, and the palace is right to the left in the scene. You barely see the corner of the fence in my test render. I was thinking of really worn down cobbles partly intermixed with dirt - as being pressed down, worn out.
          Thought I'd do a large texture for this. But maybe I should give it a go with modelling...
          • numbthumbN Offline
            numbthumb
            See if you can use these.
            stone.zip
            Comfortably numb...
            • Mike LuceyM Offline
              Mike Lucey
              Thom, here are a few more.
