    Solid object
    2 Posts 2 Posters 393 Views 2 Watching
    • F Offline
      fymoro
      Hi all,
      Is there a solution to export a SU file in a solid object format ?
      I explain, even when I export a SU file in 3d-DWG, it is not recognized as a solid object.
      There is some add-on for Autocad to import directly a SU file into it, But they are not free, and also you must have Autocad...
      Thanks for your help... 😉
      http://www.thearender.com/cms/index.php/news/featured-artists/137-frederic-yves-moro.html
      • sketch3d.deS Offline
        sketch3d.de
        no solids in SU, mesh based faces only, better use a 3D NURBS surface and volume modeler instead.
        hth,
        Norbert
