    Cold outside ?
    18 Posts 10 Posters 1.3k Views 10 Watching
    • F Offline
      fymoro
      Hi all, a new project in the Alpes, Rendered with Twilight in 45 minutes high preset and a little bit of PP.
      http://www.thearender.com/cms/index.php/news/featured-artists/137-frederic-yves-moro.html
      • F Offline
        fymoro
        The night shot...
        • F Offline
          FoXar
          Nice shot, I especially like the the day one with the background where you see the tree in the top windows 👍
          • olisheaO Offline
            olishea
            gorgeous fred! ☀
            both are beautiful
            which spotlights have you used? and the underwater lights? fantastic!
            oli
            • F Offline
              fymoro
              Thanks FoXar and Oli, you can find here the two spotlights that I have used...enjoy 😉
              pool and ceiling Spot light.7z
              • FrederikF Offline
                Frederik
                It's a real pleasure to see what a real master can make... 😄
                You have adapted Twilight really fast... 👍
                Cheers
                Kim Frederik
                • F Offline
                  fymoro
                  Frederik you make shy 😳 , the more crazy in this render is that I have modeled and render it in one afternoon only... 😉
                  Your and Fletch supports in the TL forum are really precious... 👍
                    sepo
                    Great renders Fred, very nice light, great pp. I whish only that the tree was dropping shadow in the day image.
                    • tridemT Offline
                      tridem
                      👍 great work fymoro! ... and also a good TV program 😄
                      • michaliszissiouM Offline
                        michaliszissiou
                        Fred, la première scène est exceptionnelle, continue comme ça.
                        • olisheaO Offline
                          olishea
                          u did all that in one afternoon?!!!!
                          thanks for lights!
                          oli
                          • F Offline
                            FoXar
                            thanks for lights!
                            Haha seems like I'm not the only one who could improve in speed. 😳
                            Fox ^^
                              john.warburton
                              Beautiful renders.
                              Just one small suggestion - the timber cladding has an obvious pattern repeating across the wall and deck. A regular problem when applying image maps to unbroken areas. See if you can find an image that covers a larger area or which does not tile so obviously.
                              Life's a reach, and then you gybe.
                              • F Offline
                                fymoro
                                Thanks for your comments, you are right john.warburton about the texture, I will try to arange that.
                                Oli, true started at 1.30pm and finish at 5pm including render image... 👍
                                • soloS Offline
                                  solo
                                  Fred, how about an underwater render, looking up into room?
                                  That would be a great image if you can pull it off.
                                  http://www.solos-art.com
                                  • majidM Offline
                                    majid
                                    agree,nice renders 👍 and also implicitly Twilight is showing the power of humble KT
                                    • F Offline
                                      fymoro
                                      Hi Solo,
                                      Here is an underwater render 😉 When I look this image I have some difficulty to breath... 😄
                                      • majidM Offline
                                        majid
                                        also I've tried BPT (MLT) preset , and it shows caustics, when light is coming from above water
