    Cold outside ?
    18 Posts 10 Posters 1.6k Views 10 Watching
    • FrederikF
      Frederik
      It's a real pleasure to see what a real master can make... 😄
      You have adapted Twilight really fast... 👍
      Cheers
      Kim Frederik
      • F
        fymoro
        Frederik you make shy 😳 , the more crazy in this render is that I have modeled and render it in one afternoon only... 😉
        Your and Fletch supports in the TL forum are really precious... 👍
        http://www.thearender.com/cms/index.php/news/featured-artists/137-frederic-yves-moro.html
          sepo
          Great renders Fred, very nice light, great pp. I whish only that the tree was dropping shadow in the day image.
          • tridemT
            tridem
            👍 great work fymoro! ... and also a good TV program 😄
            • michaliszissiouM
              michaliszissiou
              Fred, la première scène est exceptionnelle, continue comme ça.
              • olisheaO
                olishea
                u did all that in one afternoon?!!!!
                thanks for lights!
                oli
                • F
                  FoXar
                  thanks for lights!
                  Haha seems like I'm not the only one who could improve in speed. 😳
                  Fox ^^
                    john.warburton
                    Beautiful renders.
                    Just one small suggestion - the timber cladding has an obvious pattern repeating across the wall and deck. A regular problem when applying image maps to unbroken areas. See if you can find an image that covers a larger area or which does not tile so obviously.
                    Life's a reach, and then you gybe.
                    • F
                      fymoro
                      Thanks for your comments, you are right john.warburton about the texture, I will try to arange that.
                      Oli, true started at 1.30pm and finish at 5pm including render image... 👍
                      • soloS
                        Fred, how about an underwater render, looking up into room?
                        That would be a great image if you can pull it off.
                        • majidM
                          majid
                          agree,nice renders 👍 and also implicitly Twilight is showing the power of humble KT
                          • F
                            fymoro
                            Hi Solo,
                            Here is an underwater render 😉 When I look this image I have some difficulty to breath... 😄
                            • majidM
                              majid
                              also I've tried BPT (MLT) preset , and it shows caustics, when light is coming from above water
