    Cold outside ?
    18 Posts 10 Posters 1.6k Views 10 Watching
    • F
      fymoro
      Thanks FoXar and Oli, you can find here the two spotlights that I have used...enjoy 😉
      pool and ceiling Spot light.7z
      http://www.thearender.com/cms/index.php/news/featured-artists/137-frederic-yves-moro.html
      • FrederikF
        Frederik
        It's a real pleasure to see what a real master can make... 😄
        You have adapted Twilight really fast... 👍
        Cheers
        Kim Frederik
        • F
          fymoro
          Frederik you make shy 😳 , the more crazy in this render is that I have modeled and render it in one afternoon only... 😉
          Your and Fletch supports in the TL forum are really precious... 👍
            sepo
            Great renders Fred, very nice light, great pp. I whish only that the tree was dropping shadow in the day image.
            • tridemT
              tridem
              👍 great work fymoro! ... and also a good TV program 😄
              • michaliszissiouM
                michaliszissiou
                Fred, la première scène est exceptionnelle, continue comme ça.
                • olisheaO
                  olishea
                  u did all that in one afternoon?!!!!
                  thanks for lights!
                  oli
                  • F
                    FoXar
                    thanks for lights!
                    Haha seems like I'm not the only one who could improve in speed. 😳
                    Fox ^^
                      john.warburton
                      Beautiful renders.
                      Just one small suggestion - the timber cladding has an obvious pattern repeating across the wall and deck. A regular problem when applying image maps to unbroken areas. See if you can find an image that covers a larger area or which does not tile so obviously.
                      Life's a reach, and then you gybe.
                      • F
                        fymoro
                        Thanks for your comments, you are right john.warburton about the texture, I will try to arange that.
                        Oli, true started at 1.30pm and finish at 5pm including render image... 👍
                        • soloS
                          Fred, how about an underwater render, looking up into room?
                          That would be a great image if you can pull it off.
                          • majidM
                            majid
                            agree,nice renders 👍 and also implicitly Twilight is showing the power of humble KT
                            • F
                              fymoro
                              Hi Solo,
                              Here is an underwater render 😉 When I look this image I have some difficulty to breath... 😄
                              • majidM
                                majid
                                also I've tried BPT (MLT) preset , and it shows caustics, when light is coming from above water
