    How to move the Value Control Box to the left?
    3 Posts 2 Posters 507 Views 2 Watching
    • P Offline
      PKast
      Is this possible. In an earlier version I had moved some toolbars to the bottom which brought the vc box to the left side of the screen. I can't seem to duplicate that now. Any suggestions?
      Thanks in advance.
      PK
        Hi Peter,
        In SU 7, you can activate the VCB (Measurement box) as a separate toolbar (View menu > Toolbars). In this case, it will be either undocked or docked as one of your toolbars - by default (if you can say that with SU toolbars), located on the left but above the status bar. You can however add more toolbars to this row.
        • P Offline
          PKast
          Thanks Gaieus, I will play around with that.
          Yes that works. When you activate the "Measurement" Toolbar then you can put the VCB where you want it.
