    Model this: Accelerate sofa
    21 Posts 11 Posters 3.2k Views 11 Watching
    • soloS Offline
      solo
      For the third challenge I scratched my head, I was divided between easy geometric of brutal organic, Eric (Boofredlay) came to my rescue and made a suggestion for a prototype couch called the Accelerate sofa, a sofa for high speed interior travelling created by Phillip Grass.
      It should give enough complexity for both advanced and moderate users, may be a little difficult for the noobs, but that should not stop them from trying.
      Have fun.
      http://www.solos-art.com
      • broomstickB Offline
        broomstick
        egad!
          liam887
          right im all over this one! Good luck everybody!
          VISIT MY ONLINE GALLERY
            rev3rse
            What kind of sofa is this? A piece of post-modern art.. but really outstanding.. πŸ˜„
            • jeff hammondJ Offline
              jeff hammond
              feeling out an approach.. tried it with the scale tool at first but figure it would end up taking a long time fiddling around..
              gonna try this approach which took less than ten minutes.. some of the blends may prove difficult but this one is doable for sure.. hopefully 15+ submissions for this thread..
              EER
              dotdotdot
              • EarthMoverE Offline
                EarthMover
                Here's a quick stab with SDS. Proxy needs more work, but it's getting there.
                Content Creator at Skapeup
                • boofredlayB Offline
                  boofredlay
                  Here is my first shot. Ok I confess, it is my second shot. I tried this couch about a year ago and gave up too soon. I guess I have learned a few things since then.
                    jeff hammond
                    WIP.. i'll try to finish the back and get more proper scaling tomorrow..
                    mostly bezier spline and extrude edges by rails
                    dotdotdot
                      boofredlay
                      Nice work Jeff.
                      For the proxy I only used native SU tools. Then I ran Subdivide and Smooth, 2 iterations. Then for the lines I "unhid" most then connected others with Tools on Surface, mainly the line; the arc had some funky results.
                      I added the lines and used a heavy profile as well as depth cue for these.
                        jeff hammond
                        love the lines eric!
                        mine needs a redraw from scratch to get some of the parts better but i'll pass..
                        .skp attached below
                        engine_couch_JH.skp
                        dotdotdot
                          EarthMover
                          Great work!
                          Boo, could you possible use the 2D tools line styles to add weight to the lines to make them renderable?
                            boofredlay
                            Not sure. I have not used the 2D tools at all.
                              jeff hammond
                              you could maybe use tools_on_surface offset to make a paintable strip for rendering ?
                              dotdotdot
                                boofredlay
                                Well the lines are on the model. I just unhid ones that were where they needed to be and used TOS to fill in the gaps. And I also used the knife from SDS to do the lines across the seat and back as the mesh did not align properly.
                                I can share the model tonight when I get home.
                                  boofredlay
                                  Here it is. SU_v6.
                                  Accelerate_v6.skp
                                  • CarrozzaC Offline
                                    Carrozza
                                    Excellent examples of organic modeling within Sketchup!
                                    • olisheaO Offline
                                      olishea
                                      these are great. well done guys. would love to place one in an interior.
                                      oli
                                        EarthMover
                                        Eric,
                                        Thanks for sharing the model. I isolated the lines and ran the convert lines to cylinders plugins at 1/2" and 6 segments. This made the lines renderable. Added to that a quick Sepo pencil overlay.
                                        Unfortunately converting the lines to cylinders also doubled the file size.
                                          sepo
                                          Great modeling Eric.....nice one Adam πŸ˜„
                                          • W Offline
                                            weizxwilliam
                                            my First attempted
                                            • 1 / 2
