    Model this: Accelerate sofa
    21 Posts 11 Posters 3.2k Views 11 Watching
    • broomstickB Offline
      broomstick
      egad!
        liam887
        right im all over this one! Good luck everybody!
        VISIT MY ONLINE GALLERY
          rev3rse
          What kind of sofa is this? A piece of post-modern art.. but really outstanding.. πŸ˜„
          • jeff hammondJ Offline
            feeling out an approach.. tried it with the scale tool at first but figure it would end up taking a long time fiddling around..
            gonna try this approach which took less than ten minutes.. some of the blends may prove difficult but this one is doable for sure.. hopefully 15+ submissions for this thread..
            EER
            • EarthMoverE Offline
              EarthMover
              Here's a quick stab with SDS. Proxy needs more work, but it's getting there.
              Content Creator at Skapeup
              • boofredlayB Offline
                boofredlay
                Here is my first shot. Ok I confess, it is my second shot. I tried this couch about a year ago and gave up too soon. I guess I have learned a few things since then.
                  WIP.. i'll try to finish the back and get more proper scaling tomorrow..
                  mostly bezier spline and extrude edges by rails
                    boofredlay
                    Nice work Jeff.
                    For the proxy I only used native SU tools. Then I ran Subdivide and Smooth, 2 iterations. Then for the lines I "unhid" most then connected others with Tools on Surface, mainly the line; the arc had some funky results.
                    I added the lines and used a heavy profile as well as depth cue for these.
                      love the lines eric!
                      mine needs a redraw from scratch to get some of the parts better but i'll pass..
                      .skp attached below
                      engine_couch_JH.skp
                        EarthMover
                        Great work!
                        Boo, could you possible use the 2D tools line styles to add weight to the lines to make them renderable?
                          boofredlay
                          Not sure. I have not used the 2D tools at all.
                            you could maybe use tools_on_surface offset to make a paintable strip for rendering ?
                              boofredlay
                              Well the lines are on the model. I just unhid ones that were where they needed to be and used TOS to fill in the gaps. And I also used the knife from SDS to do the lines across the seat and back as the mesh did not align properly.
                              I can share the model tonight when I get home.
                                boofredlay
                                Here it is. SU_v6.
                                Accelerate_v6.skp
                                • CarrozzaC Offline
                                  Carrozza
                                  Excellent examples of organic modeling within Sketchup!
                                  • olisheaO Offline
                                    olishea
                                    these are great. well done guys. would love to place one in an interior.
                                    oli
                                      EarthMover
                                      Eric,
                                      Thanks for sharing the model. I isolated the lines and ran the convert lines to cylinders plugins at 1/2" and 6 segments. This made the lines renderable. Added to that a quick Sepo pencil overlay.
                                      Unfortunately converting the lines to cylinders also doubled the file size.
                                        sepo
                                        Great modeling Eric.....nice one Adam πŸ˜„
                                        • W Offline
                                          weizxwilliam
                                          my First attempted
                                            boofredlay
                                            Thanks Sepo.
                                            Nice work WEi.
