    Model this: Accelerate sofa
    21 Posts 11 Posters 2.8k Views 11 Watching
    • EarthMoverE Offline
      EarthMover
      Here's a quick stab with SDS. Proxy needs more work, but it's getting there.
      Content Creator at Skapeup
      • boofredlayB Offline
        boofredlay
        Here is my first shot. Ok I confess, it is my second shot. I tried this couch about a year ago and gave up too soon. I guess I have learned a few things since then.
        • jeff hammondJ Offline
          WIP.. i'll try to finish the back and get more proper scaling tomorrow..
          mostly bezier spline and extrude edges by rails
            boofredlay
            Nice work Jeff.
            For the proxy I only used native SU tools. Then I ran Subdivide and Smooth, 2 iterations. Then for the lines I "unhid" most then connected others with Tools on Surface, mainly the line; the arc had some funky results.
            I added the lines and used a heavy profile as well as depth cue for these.
              love the lines eric!
              mine needs a redraw from scratch to get some of the parts better but i'll pass..
              .skp attached below
              engine_couch_JH.skp
                EarthMover
                Great work!
                Boo, could you possible use the 2D tools line styles to add weight to the lines to make them renderable?
                  boofredlay
                  Not sure. I have not used the 2D tools at all.
                    you could maybe use tools_on_surface offset to make a paintable strip for rendering ?
                      boofredlay
                      Well the lines are on the model. I just unhid ones that were where they needed to be and used TOS to fill in the gaps. And I also used the knife from SDS to do the lines across the seat and back as the mesh did not align properly.
                      I can share the model tonight when I get home.
                        boofredlay
                        Here it is. SU_v6.
                        Accelerate_v6.skp
                        • CarrozzaC Offline
                          Carrozza
                          Excellent examples of organic modeling within Sketchup!
                          • olisheaO Offline
                            olishea
                            these are great. well done guys. would love to place one in an interior.
                            oli
                              EarthMover
                              Eric,
                              Thanks for sharing the model. I isolated the lines and ran the convert lines to cylinders plugins at 1/2" and 6 segments. This made the lines renderable. Added to that a quick Sepo pencil overlay.
                              Unfortunately converting the lines to cylinders also doubled the file size.
                                sepo
                                Great modeling Eric.....nice one Adam πŸ˜„
                                • W Offline
                                  weizxwilliam
                                  my First attempted
                                    boofredlay
                                    Thanks Sepo.
                                    Nice work WEi.
