    Extra lines in curves
    layout
    4 Posts 2 Posters 1.2k Views 2 Watching
    • J
      jsteacy
      Sometimes I get extra lines in my curves in layout when it doesn't exist in SketchUp. Maybe it's a hidden line that wasn't processed properly so how do I fix it? It only seems to happen in parallel projection iso views of the model (Which I use all the time!).
      Any suggestions? right now I have to re-orient the model in layout very slightly and for whatever reason the line will disappear.
      jsteacy
      from layout
      from sketchup
      from sketchup with hidden lines on
      • J
        jhauswirth
        Are you doing vector or hybrid rendering?
        • J
          jsteacy
          hybrid
          • J
            jhauswirth
            @jsteacy said:
            hybrid
            This is a bug that you can't do anything about, other than change the
            camera slightly like you have been doing. What version are you using?
            You can submit a bug and make sure to send in the example that shows
            the problem.
