    How to make a structural curvy roof [tutorial]
    24 Posts 13 Posters 20.1k Views 13 Watching
      chang11234
      http://wpcontent.answers.com/wikipedia/commons/thumb/1/19/British_Museum_Great_Court_roof.jpg/250px-British_Museum_Great_Court_roof.jpg
      How can I make a roof like this? I have made a curvy plane, but don't know how to make a structural frame like on the picture.
        remus
        i think the easiest thing to do would be to model the overall shape of the roof using subdivide and smooth then use lines2cylinders or similar to turn all the linework SDS creates in to the structural elements of the roof.
        subdivide and smooth: http://www.smustard.com/script/SubdivideAndSmooth
          one module (or more) + Component Stringer seems more appropriate ๐Ÿ˜‰
          Difficulty is found the curves ๐Ÿ˜‰
            How about Didier's lines2tubes plugin?
            http://forums.sketchucation.com/viewtopic.php?f=180&t=12354
              Problem of Didier's Plug is that intersections are not solved at any level of precision! ๐Ÿ˜ฎ
              (triangle, square,...circle ๐Ÿ˜’
              Else it's a very funny plug! Cool for a render from distance but not for precision ๐Ÿ˜‰
              Depending of what you do you want ๐Ÿ˜„
              http://forums.sketchucation.com/download/file.php?id=13863&mode=view
                chang11234
                Thank you guys, I try the lines2tube, works realy well.
                • daleD Offline
                  dale
                  Looks like a gridshell. If your interested here is a link to the Downland Gridshell site.http://www.wealddown.co.uk/Buildings%20and%20Exhibits/gridshell/downland-gridshell-construction-progress.htm
                    Example...CurvedRoof.pngCurvedRoof.skp
                      Yes perfect for presentation โ˜€ but not for fabrication ๐Ÿ˜‰
                      • mitcorbM Offline
                        mitcorb
                        Pilou wrote: Problem of Didier's Plug is that intersections are not solved at any level of precision! ๐Ÿ˜ฎ
                        Pilou, I have been modelling pipes and cables on a roof with Lines2tubes. The roof area is full of mechanical equipment and pipes. What I do is use SU arc tool to fillet the angles, erase the segments after fitting the arcs, and then run the conversion. This makes the turns somewhat smooth--not perfect, but at the right viewing distances and the diameters of the pipes and cables at 1/2" or 2" or 3", it is sufficient for my "as-built" model. And I use this model for decisions on how to eliminate these pipes and cables in corrective construction.
                        mitcorb
                          @Mitcorb
                          Of course! ๐Ÿ˜„
                          I have written
                          ๐Ÿ˜‰
                          Here the British Museum system shown on the first post ๐Ÿ˜‰
                          http://communities.bentley.com/photos/matteosarroccos_images/images/58188/290x480.aspx
                            Who would ever want to make fabrication information this way !
                            It's only a 'model' !
                            If you made it out of cardboard and balsa-wood you'd not make it exactly as it'll be made when full-size...
                            If I were to make fabrication info using only SUp I'd detail typical elements and intersections separately, not in the overall model - that's only there to show us what it will look like, not how to build it !
                            ๐Ÿค“
                              Of course yes โ˜€
                              But as computer permit to make any precise structures, if it's not a painful work this can be made in one time ๐Ÿ˜‰
                              Who can make more can make less ๐Ÿ˜„
                                Slimdog
                                Yes looks simple for the architect or modeler but would be a hand full for the steel detailer and fabricator.
                                  mambo.harts.u
                                  Hello! I am also working on this kind of project. The thing is its a pretty big file ones you made the space frame by the lines2tube script. But if that's only way better stick to it!
                                  My problem is, is there a way that i can reduce the file size so its would be easier to work on the whole project? Maybe reducing the poly lines or anything?
                                  Any help is appreciated! TIA!!
                                  • simon le bonS Offline
                                    simon le bon
                                    I have worked on this.
                                    I'm to explain it in Tutorial Section
                                    http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/dome001_kt_th.jpg
                                    ๐Ÿ˜‰ simon
                                      simon le bon
                                      Done!
                                      structural curvy roof answer
                                      ๐Ÿ˜Ž
                                        stevebo
                                        Hi Pilou. Do you know where you got this image? I'm working on a project which will use a similar construction, and would love to get some details of the Great Court!
                                        Thanks!
                                          Here ๐Ÿ˜‰
                                            stevebo
                                            Merci Beaucoup ๐Ÿ˜„. Now time to learn to model this ***** ๐Ÿ˜„
                                            • 2 / 2
