    A dynamic component in a dynamic component
    1 Posts 1 Posters 1.0k Views 1 Watching
    • C
      carlogonzalez
      a dynamic component in a dynamic component
      by carlogonzalez on Tue November 24, 2009 7:31 pm
      voila I created a CDynamique (a cinderblock wall), everything works, I
      can adjust the length, thickness and the cinderblock wall height.
      problem
      when I made a composantDy with 4 walls of that ComDy. to come
      Just the coats of the slab (length width) component Dy wall
      is inside the component dy house not responded more as a component
      dynamic, it is freezing. Similarly, in the attribute window, if it has
      former group (block 20X20X40 a cinder block) that we made a first
      dynamic component to put a cinderblock on the other, in
      This window was the name of the component "wall" with all the below
      group "cinder block".
      whereas if we make a dynamic component "home" call of faith 4
      the dynamic component "wall".
      in the window attribute is more than, comp house, below, wall 1,
      wall etc. 2. and nothing else, the subgroup "cinder block" of component
      dynamic "wall" no longer appear, well, there are more dynamic.
      there is also a solution for the future it does not suits me: do not
      a single component with all the dynamics inside cinder block name
      "mur1 cinder block, cinder block wall 2" to the various fronts.
      I already made but I pose problems for later
      related specifications, carpentry etc..
