๐ Smart Spline | Fluid way to handle splines for furniture design and complex structures. Download
How to bend a belt?
Hullo everybody,
I am pretty new on sketchup and I am in need of your help.
I have draw an iron belt or if you will a belt like you use to tie your jeans. The belt start vertically and ends horizontally, this is the basics but here is the real task: see attachment.
Thanks a tons in advance for your help
read this: http://forums.sketchucation.com/viewtopic.php?f=180&t=23662&st=0&sk=t&sd=a&hilit=extrude
it is your best solution.
