    How to get face uvs if texture is applied to component inst
    18 Posts 5 Posters 1.4k Views 5 Watching
    • J
      jbacigalupa
      I'm writing some ruby scripts related to faces and uvs. I am unsure how to get uv information from my faces when the material is not directly applied to the face. Here is my test scenario.
      1. Make a circle and extrude it to be a cylinder
      2. Select the cylinder and make it a component
      3. Apply a texture material to that component instance
      4. Adjust the texture's uv repeat information as needed
      The only way I can get the uv information is if I manually apply the component instance's material to the faces prior to loading them into a TextureWriter and grabbing a UVHelper, etc. The problem with this is when I call face.material= or face.back_material= it apparently makes the edge smooth tool think that this face is no longer part of a curve and I get faceted edges.
      So I'm kinda stuck between a rock and a hard-place. I can either have correct uv information but any curved surfaces get screwed up, or I can have smooth surfaces with no uv information. I guess the third option is I can force people to apply textures to the faces only - but I don't like forcing odd things like this on the users...especially if it appears correctly in the Sketchup viewport.
      I must be missing something simple - so hopefully someone can clear this up for me. How can I get uv information for the "actual" material that is being used on the face?
      If you need any clarification feel free to ask - I'd really like to solve this issue. I could probably write a quick script to fully demonstrate the problem, but I figured I would see if anyone had run into this issue before I did that.
      Thanks!
      Joe Bacigalupa
      • thomthomT
        I thought this issue sounded familiar. Then I read your name. πŸ˜‰
        Hi there Joe.
        • thomthomT
          The adjacent becomes faceted? How do you mean? If I set a face' material on a cylinder's smooth surface, the edges still report back .soft? and .smooth?
          Are you seeing something differently? Or are you measuring faceted differently?
          • thomthomT
            I'm looking at the UV data returned for faces with Default material. The values seems to be related to inches from the containing group/component or model.
            This cylinder is 100" above ground, and 100" tall. Notice the V value for that face. What is you took the UV values for faces with default material and divided by the width and height of the Material.texture?
            Will that give matching UV data? If so, then that should be a lot faster than applying the material to the faces, sample UV data, then remove it again.
            • J
              jbacigalupa
              Hi there Joe.
              Hey Thom πŸ˜„ I was going to post this on the Sketchup api site but it looks like they don't really have a Ruby section any more. Devin suggested I check this site out instead.
              Let me show you a picture of what I get on my end...
              This is when I apply a material to the component instance:
              http://img267.imageshack.us/img267/139/facets.jpg
              This is when I apply the material directly to the faces:
              http://img692.imageshack.us/img692/2356/nofacets.jpg
              You can see the outline of the faces completely in render 1 - and in render 2 you can't. So that is where my assumption about the smooth tool came from. I am not sure if thats what it is but it seems like I'm breaking a "connection" or something when I modify the material. Maybe if I could do a batch material apply operation it would work out better...but since this is just a workaround to get uv info I don't want to muck around too much with the person's scene.
              Joe Bacigalupa
              • J
                jbacigalupa
                Yeah I'd imagine I could just homebrew my own uv information but I'd rather just use theirs if possible. I am not sure if your solution would take into account the various translations, etc, that can be done with textures on faces.
                Joe Bacigalupa
                • W
                  Whaat
                  You can get the UVs by extracting the PolygonMesh object from the face. (Face.mesh)
                  The UVs that you will get will need to be divided by the texture size that is set using the SketchUp materials editor. If the texture is applied directly the face, you can get the UVs directly (i.e. not dividing by the texture height and width).
                  • J
                    jbacigalupa
                    Ok I will give that a shot, I thought I was just getting garbage uvs...I hadn't thought that they were the actual uvs just not set to the proper repeat value. Wow...
                    I'll let you know how this goes.
                    Joe Bacigalupa
                    • thomthomT
                      I did a quick test. I took the UV data from the faces with default material, and divided them with the Height and Width of the components material's texture, and then used position_material. The mapping seemed to be identical.
                      default_uv.rb
                      • thomthomT
                        I've seen that happen. But I don't understand why. What do you do to determine if two faces should be smoothed?
                        As mentioned, the edge.smooth? and edge.soft? seem to remain true after you apply a material to the faces connected to it.
                        • thomthomT
                          Ah! Didn't see that post. Seems to confirm my theory and testing.
                          I guess this means, the parsing of groups/components with materials applied to them won't produce such an overhead any more. πŸ˜„
                          • dkendigD
                            dkendig
                            Shhh, don't jinx it... Joe got sucked off to a meeting, but we have managed to render a sphere with no faceting so far! I don't know what kind of impact this will have on scene parsing... fingers are crossed.
                            Devin Kendig
                            Developer
                            • J
                              jbacigalupa
                              πŸ˜„ Yeah - so far it looks like the width/height divide was all we needed. Thanks to Whaat and ThomThom for your help - that issue has annoyed me for so long.
                              I wish I came to this forum sooner!
                              Joe Bacigalupa
                              • thomthomT
                                Doesn't a PolygonMesh return only triangles? Can you get UV data for distorted textures from just 3 points?
                                Face.position_material requires four samples to set a distorted texture.
                                Here, sample file:
                                uv_sample.skp
                                It contains two identical faces, both triangles. One face has a distorted texture, the other not.
                                uv_sample.rb
                                This script has two different methods to copy the UV mapping from the one face to the other.
                                Select the two faces, ensure one of them does not have a material applied, and try out the following two methods.
                                sample_vertex - samples UV data from the three vertices of the triangle. Notice that the transferred texture does not match.
                                sample_plane - Picks four points from the face's plane. Notice that the transferred texture is identical.
                                • W
                                  Whaat
                                  thomthom:
                                  have you released that UV inspector plugin that you show in one of your posts above? I was looking for it the other day and I couldn't find it. It would be really useful to me.
                                  • N
                                    nomeradona
                                    seems were having a good news for vraysu here.... β˜€
                                    visit my blog: http://www.nomeradona.blogspot.com
                                    • thomthomT
                                      @whaat said:
                                      thomthom:
                                      http://forums.sketchucation.com/viewtopic.php?f=180&t=21472
                                      Though, I just noticed some weirdness when probing through groups/components. When I was testing the cylinder I'd draw the info correctly for every other face. πŸ˜• Need to track down a bug there.
                                      • W
                                        Whaat
                                        Thanks Thomas!
