    How can i put an logo (jpg picture) on a curved wall
    5 Posts 5 Posters 968 Views 5 Watching
    • H
      hvanessen
      Hi everyone,
      I would like to know if it is possible to put an logo, what is a jpg graphic picture, as a texture on a curved wall.
      I like it to use with my new project. Because i only just started i have no file or sample of it. 😕
      • mitcorbM
        mitcorb
        I believe there is a right click context command in SU for placing the image called Projection. Most definitely, check out the SU Help options on the top line menu. Or, wait a while, and wiser heads will weigh in to help you.
        Good Luck, mitcorb
        see? dedmin faster than me.
        • D
          dedmin
          I also recommend to watch all the videos from this guy - excellent for starters!
          http://www.youtube.com/user/aidanchopra#p/u
          • GaieusG
            Hi Henk,
            There are a couple of examples how to do it here:
            http://forums.sketchucation.com/viewtopic.php?f=15&t=13564
            (download the skp files and follow the steps in each scene by clicking on the scene tabs).
            • Alan FraserA
              Alan Fraser
              You can wrap an image clear around a curved shape...as long as the sides are vertical. In the attached file, an extruded circle has been rotated so that one of its flat sides is facing along an axis (therefore exactly parallel to the imported image).
              The image is projected onto that face. You then r-click the face, uncheck the Projected attribute of the texture, sample the face with the now unprojected image painted onto it, then paint all the other faces.
              wrapped.skp
              3D Figures
