    How to apply attributes through code? and how do they work?
    21 Posts 4 Posters 1.9k Views 4 Watching
    • TIGT
      Things [each called an Entity] that are 'visible' in a model are typically geometry [lines, faces etc], and groups and components [what is commonly called a component is actually a 'component-instance']. These groups and instances contain geometry - they can also contain sub-groups and other instances. This is a simplified picture since there's also Images, Text, Dimensions etc etc but lets keep it simple !
      Within the model's 'database' there are other things you can't see but that you can use - inside 'collections' called Materials, Layers, Styles and ComponentDefinitions. Each of these will have entries like Material, Layer, Style and ComponentDefinition.
      So far so good ?
      When you look at the Components in the Browser you are looking into the model's database and seeing the Component-definitions available for use.
      When you select [highlight] something in a model you can get its 'class' [typename etc] so with the initial examples above you have Sketchup::Edge, Sketchup::Face, Sketchup::Group and Sketchup::ComponentInstance.
      Let's assume you have somehow set a variable instance=ss[i] which is a Sketchup::ComponentInstance.
      You can find its definition thus definition=instance.definition
      Now you can find an instance.definition but conversely you can find a definition.instances [i.e. all of that definition's instances]
      Any particular definition's instance doesn't contain anything at all - it is a marker for the definition itself, so instance.definition.entities gives you a list of entities inside the definition that that instance is using...
      You can even 'swap' an instance's definition for another one: instance.definition=another_definition ...
      • 2 / 2
