    Render this: L.E.D lighting
    38 Posts 19 Posters 13.0k Views 19 Watching
    • E Offline
      Ecuadorian
      Closer observation of LEDs reveals that only a part of the plastic is actually lit, so here's an update.
      In reality, the lit part starts with a conical shape; I'll try that tomorrow.
      -Miguel Lescano
      • EarthMoverE Offline
        EarthMover
        Miguel...the new one looks better, IMO. I think the "cone of shame" added a lot of realism. Care to post the model?
        Here's an attempt with a green LED. Not really happy with it. I used a tiny Vray sphere lighting in each of the LED's. I tried an emitter plane, but it looks crappy. Used a soft water SSS material for the bulb casing. Took forever to render the 202 lights!
        Content Creator at Skapeup
          rev3rse
          OMG!! A Point-Light for any led, it's a rendering nightmare... 😮
            Not if it's just a handful of LED for close ups.
            • olisheaO Offline
              olishea
              i think majid's and earthmover's LEDS are most convincing. majid captured that falloff that you get with LEDS...they act like mini spotlights (well the one on my keyring does anyway). So I imagine loading an IES will work well.
              oli
              • E Offline
                Ecuadorian
                OK, this time I modeled a tiny metalic "cone of shame" (he he he) around an even tinier emitter, to better simulate the light source in a LED.
                I'm not sure if I like this image better than the previous one:
                Different exposure:
                EDIT: Added the model with the cone.
                LED Closeup cone.zip
                -Miguel Lescano
                  Aidus
                  Here is mine:
                  Test Led
                  Transparent materials - real glass and that's the only correct material here 😄
                  CPU: Intel Core i7 Extreme Edition 965
                  RAM: OCZ Gold DDR3 1600MHz 12Gb
                  Video: Asus Radeon HD4870 X2 2Gb
                  Mobo: Asus P6T Deluxe 1366 Intel X58
                  • majidM Offline
                    majid
                    this is my try.sketchup + KT and also the result is a photoshop combination.
                    Also you may try it(unzip and load the KT file, attached)
                    spot light added and lit(MLT, BPT)
                    no light but sky (MLT, BPT)
                    combination and adjusted , using photoshop
                    unzip and then open in KT, 😉 cheers
                    • Al HartA Offline
                      Al Hart
                      First try
                      (I know I am a little slower at getting this done than some of you. Actually we found a bug where we were processing curved light emitters too slowly, so this helped fix up the software as well)
                      Al Hart
                      IRender nXt from Render Plus
                      • EscapeArtistE Offline
                        EscapeArtist
                        Dang. Majid, you beat me to it. I should've checked this thread before building my LED. Oh well, here it is anyway. Feel free to do what you will with it. It's a bit overboard detail-wise, I even threw in a few air inclusions.
                        Error 404 (Not Found)!!1
                        (sketchup.google.com)
                        I based it on this picture:
                        http://scorpiontheater.com/images/LED_Closeup.jpg
                        • F Offline
                          fymoro
                          A quick try (10 minutes) with Vray for SU first version... 😄
                          http://www.thearender.com/cms/index.php/news/featured-artists/137-frederic-yves-moro.html
                            Rico91
                            Hi all,
                            my first post on this forum today!
                            This is my render of the L.E.D. Lighting:
                            http://lh4.ggpht.com/_rMc47FEl0fA/SwhweInvFLI/AAAAAAAABz4/TOEACiq_BG4/Led_SUcation_2.jpg
                            [img:y90a5vdg]http://lh5.ggpht.com/_rMc47FEl0fA/Sro-DozMGPI/AAAAAAAABwU/zZsLbdpwWAs/forum_onderschrift_r3d_30pxh.jpg[/img:y90a5vdg] [url:y90a5vdg]http://www.R3Design.nl[/url:y90a5vdg]
                            • majidM Offline
                              majid
                              Ok mate, I tried to keep and respect your level of details, hope you like it 😉 (distort correction and a bit of bluring , by PS )
                                EscapeArtist
                                Oh, that is really cool. Nice job. What renderer?
                                  EscapeArtist
                                  Nice job. I used KT as well, gotta work on my materials. Only thing about KT is that it doesn't do volumetric light beams, so I got the same result as you did in your red LEDs; a bright surface light, but nothing "inside" the LED.
                                  • majidM Offline
                                    majid
                                    OK thanx mate , it is KT as usual, nice that u like it
                                    • majidM Offline
                                      majid
                                      it does volometric lighting also, but I didn't used 😉
                                      • N Offline
                                        Nick4u1
                                        Some nice attempts of rendering LED strip but you wanna try chip leds as opposed to those 5mm. This would be a lot easier..
                                        • 2 / 2
