    Offset a Path (like TOS but without a face)
    5 Posts 2 Posters 374 Views 2 Watching
    • ToboboT Offline
      Tobobo
      I'm trying to offset a downward curving line so i can creat a surface, which sort of rules out the TOS toolset.
      Any Ideas?
      Toby
      This is the slope i'm trying to offset
      Toby
      Philippians 4:13
        Something like this ?
        This is how I did it...
        Select the Sloping path and use Didier's Extrude-Line tool to make a vertical 'curtain' that's well below where we are.
        Tidy up the face orientation.
        Select all of the faces and use Joint-PushPull tool to extrude all of the faces in one go along the short length of line you had added.
        Now change the view so you can use right-left fence to select the bottoms of all of the extruded bits, leaving the top behind. You can keep the top-surface or erase it as desired...
        There was a glitch around the middle but moving a vertex or two fixed it...
        I've switch hidden geometry on.Slope.skp
        • ToboboT Offline
          Tobobo
          Thanks TIG
          Can you point me in the way of the Extrude-line tool? I'll serach for it as well.
          Toby
          Philippians 4:13
            It's one of his Projection Tools, get it here http://forums.sketchucation.com/viewtopic.php?p=167471#p167471
            • ToboboT Offline
              Tobobo
              Thanks again
              Toby
              Philippians 4:13
