    Orient Faces
    6 Posts 4 Posters 973 Views 4 Watching
    • pbacotP
      I heard of a plugin that helps orient faces correctly. Either by orienting all faces to the camera or otherwise expediting the process. I downloaded TIG Orient_Faces.Rb but nothing appears to be available. It is in the plugin folder but SU does not even report an error loading. I am using SU 6 Pro. Any way to speed this up? Seems most of the time I use a tool the faces are wrong. Thanks.
        Didier Bur has a plug on Right Click / View Based Face reversed/ Scan Model etc...
        See it at Crai Ruby Depot
        • TIGT
          My orient_faces code is a method to use within other tools - it mimics the built-in 'orient' tool... used as face.orient_faces... but you need to have defined 'face' initially...
          You need to read its notes...
          • pbacotP
            Many thanks TIG, Pilou. I'll look into it.
            Peter
            • E
              Ecuadorian
              Tomasz Marek has a plugin called "Front Face" that reverses back faces by just hovering the mouse over them. It even reverses back faces inside groups. 😲 Get it here:
              http://tomaszmarek.eu/sketchup_1.html
              -Miguel Lescano
              • pbacotP
                Thank you, Miguel. That's the one I ended up using. Thanks for the link to Tomasz' site, too. I've never looked at it before. Pretty cool.
