    Beginner Ruby Problmes
    13 Posts 3 Posters 2.0k Views 3 Watching
      Arkman
      I'm trying to create a ruby that when I create a group it just gives me a prompt to name the group. Just like it does for a component. I'm really struggling.
      Any help would be greatly appreciated.
      Thanks!
        require 'sketchup.rb'
        module AM_Named_Group
        	unless file_loaded?('am_named_group.rb')
        		# Add menu items.
        		plugins_menu = UI.menu('Edit')
        		plugins_menu.add_item('Make Named Group')	{ self.named_group }
        	def self.named_group
        		model = Sketchup.active_model
        		sel = model.selection
        		# Don't do anything if the selection is empty.
        		return if sel.empty?
        		# Ask user for group name.
        		prompts = ['Group Name; ']
        		defaults = [model.definitions.unique_name('Group#1')]
        		input = UI.inputbox(prompts, defaults, 'New Group')
        		# Check if the user cancelled.
        		return if input == false
        		# The add_group method can be buggy when you pass on entities to it's argument. But there's
        		# no real options.
        		group = model.active_entities.add_group(sel)
        		name = model.definitions.unique_name(input[0])
        		# We set the name we will see in the Entities window.
        		group.name = name
        		# We set the definition name as well. If you convert the group to a component, this is the
        		# name it will get.
        		group.entities.parent.name = name
        		# Select the new group
        		sel.clear
        		sel.add(group)
        file_loaded('am_named_group.rb')
          Arkman
          Awesome! I have one more request. How could I get a list of layers in the model to define what layer it lives in. I can get a list but I can't get it to show the layers in the model or place that newly created group on the layer.
          Thanks!!!!
            Thanks!!!!
            You can get a list? But you can't get it to show the layers in the model...
            I'm not quite following you. What list are you "getting"? You mean a list in the inputbox?
            All the layers are under Skethcup.active_model.layers
            http://code.google.com/apis/sketchup/docs/ourdoc/layers.html
              		# Add menu items.
              		# Build an array of the layer names.
              		layers = model.layers.to_a.collect { |l| l.name }
              		list = ['', layers.join('|')]
              		prompts = ['Group Name; ', 'Layer; ']
              		defaults = [model.definitions.unique_name('Group#1'), model.active_layer.name]
              		input = UI.inputbox(prompts, defaults, list, 'New Group')
              		# Get data from result array into variables
              		group_name, group_layer = input
              		# Make it into one Undoable action
              		model.start_operation('Make Named Group')
              		# no real options.
              		name = model.definitions.unique_name(group_name)
              		group.name = name
              		# name it will get.
              		# Set group layer
              		group.layer = model.layers[group_layer]
              		sel.clear
              		sel.add(group)
              		model.commit_operation
                Arkman
                Ok, sorry that was unclear.
                I can add a list to the inputbox but I cant get that list to show the layers in the model. I can make a list with just random terms that I picked. Like below.
                list = ["item1|item2"]
                So I guess my question is "How do I get a list in the inputbox that shows all the layers in the model?" I found that help file you showed me but I dont know how to use that. I tried:
                list = [Sketchup.active_model.layers]
                That didn't work. I'm not really sure how to get the list to use that Skethcup.active_model.layers
                Once the list displays the layers in the model, how do I make the object go onto the layer selected in the inputbox?
                Thanks for all your help. Sorry for all the questions.
                  @arkman said:
                  list = [Skethcup.active_model.layers]
                  That's because Skethcup.active_model.layers is a collection of Layer objects. You need to collect all the layer names from each object. You see an example in the code I posted.
                  (And Skethcup was mis-spelled)
                    Arkman
                    Incredible! Thank you so much. You just made my life a lot easier!
                      Maybe I should post it as a downloadable plugin?
                        Arkman
                        That would probably be extremely helpful. I know a lot of people that could use something like this.
                        Thanks again!!
                        Josh
                          Posted it in a separate plugin for easy searching: http://forums.sketchucation.com/viewtopic.php?f=180&t=23582
                            Scott M
                            Ththomthom I am Just starting out learning Ruby I made a plugin to create a simple rectangle based on the tutorial and would like to insert the name group module you posted could you give me some pointers?
                            https://www.youtube.com/user/ecabinetstips
                              There are some sticky thread in the Developer section where links to various best-practices is posted.
