    Beginner Ruby Problmes
    13 Posts 3 Posters 2.3k Views 3 Watching
      Arkman
      Awesome! I have one more request. How could I get a list of layers in the model to define what layer it lives in. I can get a list but I can't get it to show the layers in the model or place that newly created group on the layer.
      Thanks!!!!
        Thanks!!!!
        You can get a list? But you can't get it to show the layers in the model...
        I'm not quite following you. What list are you "getting"? You mean a list in the inputbox?
        All the layers are under Skethcup.active_model.layers
        http://code.google.com/apis/sketchup/docs/ourdoc/layers.html
          require 'sketchup.rb'
          module AM_Named_Group
          	unless file_loaded?('am_named_group.rb')
          		# Add menu items.
          		plugins_menu = UI.menu('Edit')
          		plugins_menu.add_item('Make Named Group')	{ self.named_group }
          	def self.named_group
          		model = Sketchup.active_model
          		sel = model.selection
          		# Don't do anything if the selection is empty.
          		return if sel.empty?
          		# Build an array of the layer names.
          		layers = model.layers.to_a.collect { |l| l.name }
          		# Ask user for group name.
          		list = ['', layers.join('|')]
          		prompts = ['Group Name; ', 'Layer; ']
          		defaults = [model.definitions.unique_name('Group#1'), model.active_layer.name]
          		input = UI.inputbox(prompts, defaults, list, 'New Group')
          		# Check if the user cancelled.
          		return if input == false
          		# Get data from result array into variables
          		group_name, group_layer = input
          		# Make it into one Undoable action
          		model.start_operation('Make Named Group')
          		# The add_group method can be buggy when you pass on entities to it's argument. But there's
          		# no real options.
          		group = model.active_entities.add_group(sel)
          		name = model.definitions.unique_name(group_name)
          		# We set the name we will see in the Entities window.
          		group.name = name
          		# We set the definition name as well. If you convert the group to a component, this is the
          		# name it will get.
          		group.entities.parent.name = name
          		# Set group layer
          		group.layer = model.layers[group_layer]
          		# Select the new group
          		sel.clear
          		sel.add(group)
          		model.commit_operation
          file_loaded('am_named_group.rb')
            Arkman
            Ok, sorry that was unclear.
            I can add a list to the inputbox but I cant get that list to show the layers in the model. I can make a list with just random terms that I picked. Like below.
            list = ["item1|item2"]
            So I guess my question is "How do I get a list in the inputbox that shows all the layers in the model?" I found that help file you showed me but I dont know how to use that. I tried:
            list = [Sketchup.active_model.layers]
            That didn't work. I'm not really sure how to get the list to use that Skethcup.active_model.layers
            Once the list displays the layers in the model, how do I make the object go onto the layer selected in the inputbox?
            Thanks for all your help. Sorry for all the questions.
              @arkman said:
              list = [Skethcup.active_model.layers]
              That's because Skethcup.active_model.layers is a collection of Layer objects. You need to collect all the layer names from each object. You see an example in the code I posted.
              (And Skethcup was mis-spelled)
                Arkman
                Incredible! Thank you so much. You just made my life a lot easier!
                  Maybe I should post it as a downloadable plugin?
                    Arkman
                    That would probably be extremely helpful. I know a lot of people that could use something like this.
                    Thanks again!!
                    Josh
                      Posted it in a separate plugin for easy searching: http://forums.sketchucation.com/viewtopic.php?f=180&t=23582
                        Scott M
                        Ththomthom I am Just starting out learning Ruby I made a plugin to create a simple rectangle based on the tutorial and would like to insert the name group module you posted could you give me some pointers?
                        https://www.youtube.com/user/ecabinetstips
                          There are some sticky thread in the Developer section where links to various best-practices is posted.
