    πŸ”Œ Easy Offset | Offset selected faces in SketchUp in positive and negative offsets. Download
    [Plugin] Snap to Unit
    4 Posts 2 Posters 10.3k Views 2 Watching
      alz
      Handy item that'll snap anything selected to the nearest unit described in Model Info, Units, Enable Length Snapping.
      snap_to_unit.rb
      • dereiD Offline
        derei
        What this plugin exactly does? I'm not sure that I understand from description. Can you post a movie, or a better detailed explanation?
        DESIGNER AND ARTIST [DEREI.UK](http://derei.uk/l)
          alz
          I don't have a video of it, but it's fairly simple.
          It takes whatever object(s) you have selected and moves them to the nearest "grid" setting. The grid settings are found in: Model Info: "Units". To turn on the grid also check "Enable Length Snapping" in Model Info.
          The action uses the origin point (local axis) of the object as the snap-to-location.
          • dereiD Offline
            derei
            @alz said:
            It takes whatever object(s) you have selected and moves them to the nearest "grid" setting. .
            So, if I have snapping set at 1cm and I have an object situated at 10,5cm from origin, it will be snapped to 100? (I assume that my "grid" cell is 1cm, right?)
