    Install LtPlus plugin alters uninstall.dat, uninstall.exe an
    extensions
    2 Posts 1 Posters 953 Views 1 Watching
    • S
      ScrubBurnRepeat
      After the install dialog "finished", a temp\sketchup...exe controlled regular SketchUp.exe, which started up. Su looked normal, but I noticed the only plugin in su's Plugins menu is LtPlus (and it has a few submenus).
      also windows desktop shortcut for "LTplus sketchUP PlugIN V.9.1" is same shortcut as prexisting regular SketchUp.exe shortcut.
      SketchUp.exe has same filedate as many of the dll's. Properties says it is version 7.1.4871.0
      This seems odd to me. And i don't know which other plugins have been hidden.
      I'll probably fix this by using System restore.
      I couldn't find much info about ltplus via google.
      English version: http://www.icad2000.de/LTplus_SketchUP_EN.zip
      http://www.icad2000.de/en_download.htm
      It says that ltplus plugin exports to DXF/3DS/VRML/STL.
      (using su7.1 free on winxp)
      Interesting notes about Intellicad based "cads", though these aren't su-related
      Toolbars and/or Menus are destroyed, because the IntelliCAD-Version is not
      AutoCAD-MNU/DCL-Compatible, uses absolute paths, or can't scale icons
      Standard AutoCAD- or IntelliCAD-Dialogues, or Commands are missing
      Complex Lisp-Routines don't work, because the IntelliCAD-Version uses an
      encrypting Lisp-Interpreter, where Standard-Lisp-Functions are missing
      • S
        ScrubBurnRepeat
        i think the plugin menu had not yet existed before install ltplus. seems rb writer can choose location of script commands (per google help)
        also system restore removed uninstall.exe, but i now think sketchup installer never creates an uninstall.exe (because su uses msi?)
        to investigate further, i think i'll uninstall then reinstall su, observing file changes in app folde4rs
        install some extra plugins. install ltplus. i expect the earlier plugins will still show after ltplus install.
        IOW, i suspect that ltplus only "looks funny", but is likely OK.
