    VERTEX HELP!!!!!!
    4 Posts 3 Posters 373 Views 3 Watching
    • P Offline
      pontilaki
      i am kind of new to sketch-up, but gotta say, I am loving it!
      in previousl versions i rember seeing the vertices of a line (i.e. when you select a line you can see the edge and the vertices) and it was easy to pull/manipulate one corner. on version 7.1 when i draw a line i can only see the edge, no verteces. are they turned off misteriously? and if so, how can i turn them back on?
      thank you all sketch up gurus!
        Hi Pontilaki and welcome to SCF!
        Vertices (aka endpoints) are template dependent and can be turned on under Window > Styles > In model > Edit > Edge settings.
        You can even tweak your template as much as you wish and save it as such under the File menu - then go to your Window > Preferences > Templates and choose your custom template to start SU with.
        • P Offline
          pontilaki
          gaieus,
          thanx for the quick reply. i guess that would be the "endpoints" under edges settings? seems to work now .
          thank you!!!
          • Jean LemireJ Offline
            Jean Lemire
            Hi Pontilaki, hi folks.
            The showing of vertices via the styles is only a visual effect.
            Vertices can be manipulated, whatever their appearance.
            The inference engine will show you a pop-up message "Endpoint" and a green dot when you position the cursor over any endpoint.
            Just ideas.
