    Synchronously or asynchronously
    6 Posts 3 Posters 802 Views 3 Watching
    • J
      Jim
      My understanding is that SketchUp <-> Safari communications are asynchronous, and SketchUp <-> IE communications are synchonous.
      After reading a bit about the XMLHttpRequest API, it supports a synchronous and asynchronous mode by simply by setting flag to true or false.
      Could this be used to provide a consistent communications interface between Webdialogs and SketchUp on both PC and Mac platforms?
      • thomthomT
        hmm...I don't think you and use an HTTP request to communicate with SU...
        • J
          Jim
          Thanks Thom,
          I don't know - so was just throwing the idea out to see if anyone thought it was possible.
          • thomthomT
            When we pass data back from a Webdialog to Ruby we do window.location = 'skp:some_callback' which means that Sketchup has added its own protocol skp. But the XMLHttpRequest deals with the HTTP protocol.
            If we only knew more about this skp: protocol...
            • M
              MartinRinehart
              It's possible that what you know may be all there is to know.
              Author, Edges to Rubies - The Complete SketchUp Tutorial at http://www.MartinRinehart.com/models/tutorial.
              • thomthomT
                I had a look at it. But I get an Access Denied message when I try to call back to Ruby. Turns out IE's XMLHttpRequest only works with files on the net - not local files and other stuff.
                http://www.webdeveloper.com/forum/showpost.php?s=d7e6a32ad41106e35a2d51afbce8f374&p=749574&postcount=10
