    Shape Blender
    7 Posts 2 Posters 1.1k Views 2 Watching
    • H Offline
      hoym888
      i wish to place text on circle or arc in sketchup 7.0.
      Learn that i can make use of [ progressbar.rb ] plugin ; however , i still can't find the function even i had put the required rb. file into my plugin sub-folder.
      Please help !
        Hi hoym,
        The plugin (if all the install went well) should be found under Plugins > Chris Fullmer tools.
        So you are sayng that you saved both the ShapeBender scripts and folder and Progressbar rb into the Plugins folder?
        • H Offline
          hoym888
          i just download the [ Progressbar.rb ] file but where can i find the said script.
          thanks in advance.
            At the very bottom of Chris's first post - as a zip file:
            http://forums.sketchucation.com/viewtopic.php?f=180&t=18210
            Make sure NOT to unzip it into a new folder under Plugins (Windows tends to create a folder) but straight under the Plugins folder so that you have a folder and an rb file there.
            • H Offline
              hoym888
              Great
              i eventually install the shapeblender correctly and use it.
              however, another problem crop-up : i see the newly formed object on screen but when i click on any other place with my mouse, the blended object went away . 😠 😠 😠
              why ?
                I am not sure what exactly you are doing but my suspicion is that you only see some preview of the shape. When contented with it, press Enter so that it will take effect.
                • H Offline
                  hoym888
                  Thanks !
                  problem solved.
