    Looking for a plugin to automate material colors
    5 Posts 2 Posters 463 Views 2 Watching
    • G
      gtrogers
      Hello fellow, SketchUp users! I'm new so please forgive me if I'm asking this in the wrong forum.
      Q. Does anyone know of a plugin that would take ALL of my materials and set the saturation to zero, and the brightness to 100?
      I do some projects that are greatly aided by an image that is black and white (not grayscale). Going into each color manually and adjusting the sliders gets to be a pain, especially when I need to revert back to color. Note: the hidden line viewing option isn't quite what I'm looking for as it doesn't show the textures (but it's close!)
      Thank you!
      ~Greg
      • Chris FullmerC
        One way you can do it without needing ruby is to create a new style that uses black as the default front and back face colors. THen set it so that it displays default material color, instead of materials (it is a setting similr to line mode).
        Anyhow, does that make any sense? Then you have it saved as a nice little style that you can reuse for all your models.
        Chris
        All my Plugins I've written
        • G
          gtrogers
          Chris
          Hi, Chris. Thanks for the quick reply.
          I was able to follow you all the way until you said "set it so that it displays default material color, instead of materials" which I can't quite figure out how to do.
          I opened the Styles window and went to the Face Settings and changed the front/back colors to black, but I didn't notice any change in my model. I'm sure it's something obvious, but how do I do the "display default material" thing you mentioned?
          Thanks again!
          • Chris FullmerC
            The button is called color all the same or something like that. Here's a screen grab that shows it. Hope it helps, let me know if it does not do quite what you were hoping for.
            Chris
            • G
              gtrogers
              [attachment=0:3e6t77oc]<!-- ia0 -->all_same.png<!-- ia0 -->[/attachment:3e6t77oc]
              Chris
              Ahh, ok, now I see what you're talking about! I followed your instructions and the model did indeed turn all white, but it's lacking its textures, unfortunately.
              Let me show you an example of what I'm looking to do:
              I model with color data and presentation purposes:
              http://dl.dropbox.com/u/119011/LULZ/sketchup texture with color.jpg
              For certain rendering effects and photoshop post-processing, it's VERY handy to keep the textures, but have them have no saturation and full brightness:
              http://dl.dropbox.com/u/119011/LULZ/sketchup texture no color.jpg
              There may be no easy way to do this other than old-fashioned elbow grease. It just gets very redundant, very quick to manually adjust each material πŸ˜„
